Installation Error: failed to map segment from shared object: Operation not permitted
OS Name/Version: CentOS 7 w/CPanel
Product Name/Version: (Always use the full version number - not ‘Latest’) GetAMP v3.0.1
I am trying to install but I keep getting the following error:
Error loading shared library: /tmp/mono-bundle-lLXhSE/libsqlite3 /tmp/mono-bundle-lLXhSE/libsqlite3: failed to map segment from shared object: Operation not permitted
I get two of these errors every time I try to install, each with a different directory name, but all directories follow the pattern /tmp/mono-bundle-######
Each install attempt creates two new directories that follow that pattern.
Mono is not installed on my machine:
[root@mymachine]# mono -version
-bash: mono: command not found
  • bash <(wget -qO- getamp.sh)
  • Also happens with ampinstmgr -version
  • Removed the sticky tag on the /tmp directory
Trash any mono files/directories in /tmp/
I did that. The installation process just creates more.
Is /tmp/ mounted as noexec?
It’s not mounted. It’s on the main filesystem.
That may be why. It doesn’t have permission to execute stuff it needs to from /tmp/ - is your configuration non standard in some way?
Edit: Also I see you’re on CentOS 7 - you should upgrade soon because support for it is being dropped later this year. End-of-support announcements for Linux and Windows versions
