How are you supposed to add port exclusions to an AMP instance? I have a game server running that requires access to an outside metrics server on a port other than the port the game uses.
I assume AMP is firewalling the instance somehow, it’s not really explained in the setup tutorials and I can’t find any information on that on this forum.
I’m guessing we’re supposed to ‘Edit Ports’ on the instance and add the port there; I just get ’ Unable to add port exemption’ every time I try to do that.
That is the correct thing to do in order to add extra ports. Could you check AMPs log to see if it gives any information about why it can’t make that change?
I’m a little confused by the log layout but ADS01 logs show the following at approximately the last time I tried to add the port exclusion so may be related to it:
