AMP Controller cant create Custom Port on Target - "Unable to add port exemption"
OS Name/Version: Ubuntu Server 22.04 LTS
Product Name/Version:
AMP Release “Decadeus”
v2.4.8, built 29/01/2024 18:40
I have a Controller / Targets Setup and want to create a Custom Port to an Instance with a Minecraftserver over the Controller but i get there Errormessage “Unable to add port exemption”
When i go over the way to manage the Target directly i can add my Port without isues.
  • Step 1
  • Create a Instance on a Target
  • Step 2
  • Click on the Instance and on “Edit Ports”
  • Step 3
  • Add a Custom Port and click on “+”-Button
According to this entry, the port is created directly via the target
How to open ports for instance? - Technical Support - CubeCoders Support
Known issue, for now the workaround still applies. Manage the target then add the port there.
When it / will be patched?
