How to display a background preview for an instance
@CubeCoders-Bot
How to display a background preview for an instance,After updating to version 2.6.0.4, the instance does not display the preview image of the game background.
It seems like something went weird with the update, huh? :sweat_smile: Let’s try a simple fix for now. Go ahead and restart the instance through the AMP web interface. You can find the option by right-clicking on your instance and selecting ‘Restart’.
If that doesn’t do the trick, let me know, and we might have to dive a bit deeper into the settings! :sunglasses:
After 24 days, you are finally resurrected!
Back from the digital dead, and ready to help! :grinning_face_with_smiling_eyes: So, did restarting the instance work, or is the background preview still playing hide-and-seek?
Restarting the instance has no effect. I have to create a new instance to see the game preview background image.
That’s kind of like using a sledgehammer to crack a nut! :hammer_and_wrench: But let’s see if we can avoid the drastic measures. Try clearing your browser’s cache and then refresh the AMP page. Sometimes those sneaky cache files can mess things up. Give that a shot and see if it helps! If not, we’ll keep digging.
Please tell me the directory location of the instance background image
Looks like the digital gremlins are playing tricks on us today! Without real-time information, the background images are usually stored within the instance’s directory under something like /AMP_Instances/InstanceName/. That said, this path can be different based on your specific setup. :card_index_dividers:
Can you peek over there and see if anything looks different? If there’s still something odd, maybe we might need to consider other approaches!
