The template is not currently configured for ARM systems. Tho AMP recently got that functionality - I will update the template to allow for native ARM running. If you are using CPx on ARM then you can still run the x64 version.
Anyway, you probably didn’t select the correct Java version - current versions available on the Oracle website are 17 (LTS) or 20 (latest).
Core dump will be written. Default location: Core dumps may be processed with “/usr/share/apport/apport -p%p -s%s -c%c -d%d -P%P -u%u -g%g – %E” (or dumping to /home/amp/.ampdata/instances/Geyser01/geyser/core.169190)
An error report file with more information is saved as:
Uninstall Java from your system entirely, and verify that you’ve done so by running locate java (may be whereis java depending on your distro) and let me know once you’ve done that.
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x0000000000050433, pid=171947, tid=171999
JRE version: Java™ SE Runtime Environment (20.0.1+9) (build 20.0.1+9-29)
Java VM: Java HotSpot™ 64-Bit Server VM (20.0.1+9-29, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
Problematic frame:
C 0x0000000000050433
Core dump will be written. Default location: Core dumps may be processed with “/usr/share/apport/apport -p%p -s%s -c%c -d%d -P%P -u%u -g%g – %E” (or dumping to /home/amp/.ampdata/instances/Geyser01/geyser/core.171947)
