It must be because you are on an ARM system and trying to use the x64 Java version, but don’t have CPx installed (as per my first post).
Wait a bit and the template should be updated soon (I have submitted a PR to allow native ARM support).
I dont think the java server is starting on it so it just gives this error:
io.netty.channel.AbstractChannel$AnnotatedConnectException: finishConnect(…) failed: Connection refused: /127.0.0.1:25565
[09:41:45 INFO] TJKGaming3342 has disconnected from remote Java server on address 127.0.0.1 because of Could not reach the Java Edition server! It is either not running or not accepting connections.
Caused by: java.net.ConnectException: finishConnect(…) failed: Connection refused
at io.netty.channel.unix.Errors.newConnectException0(Errors.java:155)
at io.netty.channel.unix.Errors.handleConnectErrno(Errors.java:128)
