Err_connection_timed_out
OS Name/Version: Linux - Debian GNU/Linux 12 on x86_64
Product Name/Version: AMP ‘Phobos’ v2.6.0.6 (Mainline)
When I try to access my AMP Game Panel via internet, it only shows “ERR_CONNECTION_TIMED_OUT”.
I’ve tried with 3 different browsers on 3 different devices EACH. It’s not a problem with my firewall, I am not connected to a VPS, I just simply cannot access the AMP login screen!
All I wanted to do today was configure my server. I’m tired of all of these lame problems.
If you need any info on how to try it yourself or whatever, just ask.
BTW - The ENTIRE reason this ticket is not set up like my last tickets is BECAUSE I CANT LOGIN TO MY AMP PANEL
This is not Hostinger support, just the forum for AMP.
Please maintain a pleasant attitude while you’re here.
You may want to try and restart the VPS to see if that resolves it, otherwise you’ll need to access the VPS’s command line interface over SSH (Hostinger has guides on how to do so)
Once you got that figured, run through this update guide to ensure you’re up to date.
