Customization with Minecraft - JEI not working
Operating System windows 11
the server is not using the mod that i have placed into the mod folder, i am running forge server for 1.12.2.
  • install jei for 1.12.2
  • place into server mod folder
  • run my minecraft forge with only jei installed
  • try to use jei in the server, but it says the server must have jei installed (which it does)
Make sure you have the correct server Jar and version selected in AMP, otherwise the mods will not load.
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535
