Field
Value
Operating System
Product
AMP ‘Phobos’ v2.6.3.2 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Failed
i am trying to download cobblemon academy from curseforge and i am unable to get it to work. now my instance will not start, so i have messed something up. could you please help? i would like to know how to download different mods from curseforge. thank you.
trying to install mods
getting mods to work
successfully able to play vanilla mc
Hi,
I just tested it and it works.
Did you set fabric 0.17.2 before starting the server?
Did you set the RAM correctly?
I’m happy to help. I’m also using Docker with Debian. If need fast i can discord call but i’m in utc +1 zone
Another question: did you use the server pack or just the client pack?
Because it works very well with the server pack (connection, etc.).
This guide here goes over setting up a modded server
Preamble
Minecraft is a bit notorious for being difficult to mod, given there’s oodles of different modloaders and versions to work with, there’s edge cases galore.
If you’re new to the Minecraft modding scene and you’d like to know more about each modding platform and how they differ, check out this post here .
0. Create a new Minecraft Java Instance in AMP
Easy as that, press the Create Instance button, then select Minecraft Java Edition from the drop-down. Feel free to use an existing instan…
system
Closed
5 December 2025 20:01
5
