Customization with Application Deployment - I can not use a modpack
Virtualization VMware
I need help uploading a modpack to my server. It is from Curseforge and uses NeoForge 21.1.197. The Modpack name is “Create Chronicles: The Endventure”
  • Uploading the files
  • Run the server
  • Does not work
Check through this guide here to see if you’ve configured things correctly
I followed the guide but ended with 4 files
Run.bat Run.sh Start.bat Start.sh
Should I delete one of those?
I’m really new into this
The guide tells you how to read those files for specific version info. AMP doesn’t use the files at all, so deleting them won’t do anything.
