| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
The error output that is relevant is below:
Logging in user ‘wakuwakusteam’ [U:1:1850782717] to Steam Public…OK
11:19:11
Waiting for client config…OK
Waiting for user info…OK
workshop_download_item 233780 2126300184 validate
11:19:12
Downloading item 2126300184 …
ERROR! Download item 2126300184 failed (Failure).workshop_download_item 233780 1703187116 validate
11:19:13
Downloading item 1703187116 …
ERROR! Download item 1703187116 failed (Failure).workshop_download_item 233780 1224892496 validate
11:19:14
Downloading item 1224892496 …
ERROR! Download item 1224892496 failed (Failure).workshop_download_item 233780 541888371 validate
11:19:15
Downloading item 541888371 …
ERROR! Download item 541888371 failed (Failure).workshop_download_item 233780 1638341685 validate
Downloading item 1638341685 …
ERROR! Download item 1638341685 failed (Failure).quit
11:19:16
11:19:17
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1733269577
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 43 msec
OK
force_install_dir “233780”
Logging in using cached credentials.
11:19:19
11:19:20
workshop_download_item 233780 825179978 validate
Downloading item 825179978 …
11:19:21
ERROR! Download item 825179978 failed (Failure).quit
All relevant troubleshooting steps has already been attempted.
- Followed step by step on this installation guide for the Arma 3 server, even properly added the mod IDs of the respective mods that I want in the server : How to update AMP to the latest version
- When adding the following to the download mods portion of the AMP, it still does not seem to be correct despite it being stated to be added as such : “450814997 497660133 843425103 843577117 861133494 497661914 843632231 843593391 945476727 1180533757 1673456286 463939057 333310405 2034363662 2132195038 2126300184 1703187116 1224892496 541888371 1638341685 825179978”
- The console will then output the following errors which cannot be solved, and someone on the CubeCoder’s Discord are facing the same issues alongside others on the forum itself but no response or attempts to help them is seen. “Logging in user ‘wakuwakusteam’ [U:1:1850782717] to Steam Public…OK 11:19:11 Waiting for client config…OK Waiting for user info…OK workshop_download_item 233780 2126300184 validate 11:19:12 Downloading item 2126300184 … ERROR! Download item 2126300184 failed (Failure).workshop_download_item 233780 1703187116 validate 11:19:13 Downloading item 1703187116 … ERROR! Download item 1703187116 failed (Failure).workshop_download_item 233780 1224892496 validate 11:19:14 Downloading item 1224892496 … ERROR! Download item 1224892496 failed (Failure).workshop_download_item 233780 541888371 validate 11:19:15 Downloading item 541888371 … ERROR! Download item 541888371 failed (Failure).workshop_download_item 233780 1638341685 validate Downloading item 1638341685 … ERROR! Download item 1638341685 failed (Failure).quit 11:19:16 Redirecting stderr to ‘/home/amp/Steam/logs/stderr.txt’ Logging directory: ‘/home/amp/Steam/logs’ [ 0%] Checking for available updates… 11:19:17 [----] Verifying installation… UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1733269577 – type ‘quit’ to exit – Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 43 msec OK force_install_dir “233780” Logging in using cached credentials. 11:19:19 Logging in user ‘wakuwakusteam’ [U:1:1850782717] to Steam Public…OK 11:19:20 Waiting for client config…OK Waiting for user info…OK workshop_download_item 233780 825179978 validate Downloading item 825179978 … 11:19:21 ERROR! Download item 825179978 failed (Failure).quit”
EDIT: This has been fixed in CubeCoder discord. Issue is that you need to have a steam account that owns Arma for this to work.
