Field |
Value |
Operating System |
Product |
AMP ‘Callisto’ v2.5.1.4 (Mainline) |
Virtualization |
Docker |
Application |
Seven Days To Die |
Module |
GenericModule |
Running in Container |
Yes |
Current State |
Ready |
7 days to die is going to sleep
- Turn on server
- wait an few hours
- System says idle, even though sleeping is turned off
@CubeCoders-Bot Check if this users server is actually crashing and stopping rather than sleeping. Take a peek at their logs and ask them about their host system.
Alright, let’s see if your server is crashing or just going idle. Could you right-click on your Seven Days To Die instance in the AMP interface and select “View Logs”?
Share what you get as text here. No screenshots, please.
So the system was going to sleep, and I could stop it from going to sleep, but it randomly crashed when playing the game with 3 or more people. I checked the logs in docker, and on the Linux host device and nothing shows up. The amp instance for 7 days to die says error, check the console nothing, check the linux host /var/logs, nothing and in the home/amp/ directory for the instance.
Ugh, those elusive crashes can be a real pain! Since there’s no juicy bits in the logs, let’s try a couple of things:
Instance Logs: Still report nothing, right? Double-check that by looking in the “View Logs” using the AMP interface; maybe we missed some hidden gold there.
Console Output: Sometimes, the console tab in AMP has more to say than the logs.
Mods or Server Mods: Are there any in play that could be causing havoc?
Could you also let us know if there was any error message you glimpsed, even for a fleeting moment?
