Connectivity Problem with Minecraft - Unable to Connect to Forge Server
Hello, I am having issues connecting to the server I’m creating. When I set up a vanilla Minecraft server, I can connect without any problems. However, when I try to create a server using Forge, I am simply unable to connect.
Could you please assist me in identifying what might be causing this issue?
Thank you.
  • Created an minecraft instance
  • Downloaded Forge
  • Inserted the modpack in the server
  • Tried to join the server
Maybe double check that you’ve configured things right. There’s a modded MC guide here:
