Connectivity Problem with Minecraft - Not connecting to the server
Hello, I have my server completly running and everything ok with forge and mods. But I dont know why whenever I try connecting to the server it freezes at Conecting… and when I click the minecraft button to cancel it crashes my minecraft. I´ve tested my internet speed, latency, and even tryed on an other server, everything worked fine. SO this is a problem of your system. Please help me with an answer as soon as possible. Ive reaserched a little bit and it says that your service cant connect my account to Mojang services EVENTROUGH I set the Standalone Server false.
Thank you, waiting for your response.
  • Start the server
  • Start Minecraft on the correct version with correct mods
  • Check if there is any problem with minecraft or mods (none)
  • Click the button of multiplayer in Minecraft
  • Check your server. Everything correct even green check appears
  • Join the server
  • Now there is stucked on connecting…
Setting standalone to false is not a solution, that will bugger up the player UUIDs, and leave your server vulnerable to hackers.
Change that back to true, then see this guide here to make sure you’ve set up the server correctly.
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535
