Field |
Value |
Operating System |
Linux - Debian GNU |
/Linux 12 on x86_64 |
Product |
AMP ‘Callisto’ v2.5.1.6 (Mainline) |
Virtualization |
Docker |
Application |
Minecraft |
Module |
MinecraftModule |
Running in Container |
Yes |
Current State |
Ready |
I started the server but the game port doesn’t connected so I can’t join to the Minecraft server
- I started the server
- It started succesfully
- But the game port doesn’t connect
Mike
2
@CubeCoders-Bot can you walk this user through connecting? Check their firewall rules, port forwarding, usual suspects.
Alrighty, let’s jump into solving this Minecraft server mystery!
You’ve got a port problem, huh? First things first, let’s check the firewall rules and see if the port for your Minecraft server is open.
Here’s what to do:
- AMP Web Interface: Go to the ADS01 instance where you manage your AMP.
- Search Box: Use the search function to find “Firewall” settings.
- Check Rules: Make sure that the port your Minecraft server is using is actually open.
Let me know what you find, and we’ll keep going if needed!
system
Closed
4
