Field
Value
Operating System
Product
AMP ‘Phobos’ v2.6.3.2 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Ready
Getting “Can’t connect to server” message on server screen of minecraft, even though server is running. Trying to direct connect gives error: “Connection timed out: getsockopt”. This is only happening with NeoForge as far as I can tell. The server lets me connect if it is using vanilla minecraft.
Made server use neoforge
update and installed neoforge in game panel
start server
try to connect to server in minecraft
get error
See this guide here regarding modded setups:
Preamble
Minecraft is a bit notorious for being difficult to mod, given there’s oodles of different modloaders and versions to work with, there’s edge cases galore.
If you’re new to the Minecraft modding scene and you’d like to know more about each modding platform and how they differ, check out this post here .
0. Create a new Minecraft Java Instance in AMP
Easy as that, press the Create Instance button, then select Minecraft Java Edition from the drop-down. Feel free to use an existing instan…
If you’re with Hostinger, try connecting via the VPS’s IP instead of the domain name they gave you.
system
Closed
15 December 2025 04:43
3
