Connectivity Problem with Minecraft Bedrock - No primary endpoint to see
Product AMP ‘Deimos’ v2.7.2.8 (Mainline)
Virtualization Podman
Application Minecraft Bedrock
I have startet the server but after primary endpoint the network port status comes directly but no ip adress
  • createt the server instance
  • updated the server instance
  • Startet the server but no ip appears
@Jonathan_Keller welcome! You are not the first with this issue after upgrading. I posted yesterday to someone else’s post. Connectivity Problem with Minecraft Bedrock - cannot connect to server from the minecraft bedrock client anymore
I hope support is able to respond soon. Our server is still down.
