Connectivity Problem with Icarus - Server does not fully start up / no connection possible
Application Icarus
When I try to connect via the Steam link I get a “Unable to connect to server, app id specified by server is invalid” but the instance is also not showing listening on the game port.
  • Created a new instance for Icarus
  • Let the downloads finish until server started up - never shows as listening on game port
  • Tried updating the instance incl. template - no change in behavior
Full log
Console
Icarus - First Try (Icarus-FirstTry01)
Search…
replay
stop
Running Uptime: 0:00:04:37
play_circle
Console16:24:20
src\tier1\fileio.cpp (5307) : m_vecRegisteredWriters.Count() == 0
16:24:21
src\tier0\threadtools.cpp (3628) : Assertion Failed: Illegal termination of worker thread ‘CFileWriterThread’
16:24:22
src\tier0\threadtools.cpp (3628) : Assertion Failed: Illegal termination of worker thread ‘Thread(0x00006FFFF7C22B80/0x000’
src\tier1\fileio.cpp (5369) : CFileWriterThread already exited
Setting breakpad minidump AppID = 1149460
16:24:26
LogPluginManager: Mounting plugin AndroidPermission
LogPluginManager: Mounting plugin AppleImageUtils
LogPluginManager: Mounting plugin ArchVisCharacter
LogPluginManager: Mounting plugin AssetTags
LogPluginManager: Mounting plugin AudioCapture
LogPluginManager: Mounting plugin CableComponent
LogPluginManager: Mounting plugin ChunkDownloader
LogPluginManager: Mounting plugin CustomMeshComponent
LogPluginManager: Mounting plugin ExampleDeviceProfileSelector
LogPluginManager: Mounting plugin GooglePAD
LogPluginManager: Mounting plugin LocationServicesBPLibrary
LogPluginManager: Mounting plugin MobilePatchingUtils
LogPluginManager: Mounting plugin RuntimePhysXCooking
LogPluginManager: Mounting plugin SoundFields
LogPluginManager: Mounting plugin Synthesis
LogPluginManager: Mounting plugin AudioSynesthesia
LogPluginManager: Mounting plugin WindowsMoviePlayer
TomlLog: Display: WITH_TOML_RELOAD=0
LogInit: Using libcurl 7.55.1-DEV
LogInit: - built for x86_64-pc-win32
LogInit: - supports SSL with OpenSSL/1.1.1
LogInit: - supports HTTP deflate (compression) using libz 1.2.8
LogInit: - other features:
LogInit: CURL_VERSION_SSL
LogInit: CURL_VERSION_LIBZ
LogInit: CURL_VERSION_IPV6
LogInit: CURL_VERSION_ASYNCHDNS
LogInit: CURL_VERSION_LARGEFILE
LogInit: CURL_VERSION_IDN
LogInit: CurlRequestOptions (configurable via config and command line):
LogInit: - bVerifyPeer = true - Libcurl will verify peer certificate
LogInit: - bUseHttpProxy = false - Libcurl will NOT use HTTP proxy
LogInit: - bDontReuseConnections = false - Libcurl will reuse connections
LogInit: - MaxHostConnections = 16 - Libcurl will limit the number of connections to a host
LogInit: - LocalHostAddr = Default
LogInit: - BufferSize = 65536
LogSteamShared: Display: Loading Steam SDK 1.51
LogSteamShared: Steam SDK Loaded!
LogOnline: OSS: Creating online subsystem instance for: Steam
LogInit: WinSock: version 1.1 (2.2), MaxSocks=32767, MaxUdp=65467
[2024.07.15-14.24.26:762][ 0]LogInit: Using OS detected language (en-US).
[2024.07.15-14.24.26:762][ 0]LogInit: Using OS detected locale (en-US).
[2024.07.15-14.24.26:764][ 0]LogTextLocalizationManager: No specific localization for ‘en-US’ exists, so the ‘en’ localization will be used.
[2024.07.15-14.24.26:792][ 0]LogRendererCore: Ray tracing is disabled. Reason: not supported by current RHI.
[2024.07.15-14.24.26:801][ 0]LogInit: Using OS detected language (en-US).
[2024.07.15-14.24.26:801][ 0]LogInit: Using OS detected locale (en-US).
[2024.07.15-14.24.26:803][ 0]LogTextLocalizationManager: No specific localization for ‘en-US’ exists, so the ‘en’ localization will be used.
[2024.07.15-14.24.26:812][ 0]LogAssetRegistry: FAssetRegistry took 0.0087 seconds to start up
[2024.07.15-14.24.26:941][ 0]LogTextLocalizationManager: Compacting localization data took 2.46ms
[2024.07.15-14.24.26:941][ 0]LogStreaming: Display: FlushAsyncLoading: 1 QueuedPackages, 0 AsyncPackages
[2024.07.15-14.24.26:941][ 0]LogPackageLocalizationCache: Processed 48 localized package path(s) for 1 prioritized culture(s) in 0.000152 seconds
[2024.07.15-14.24.26:942][ 0]LogInit: Selected Device Profile: [WindowsServer]
[2024.07.15-14.24.26:943][ 0]LogInit: Active device profile: [00007F09BAECDE40][00007F09F49BD560 49] WindowsServer
[2024.07.15-14.24.26:943][ 0]LogInit: Profiles: [00007F09BAECAE40][00007F09F49BEAB0 49] Windows, [00007F09BAECDE40][00007F09F49BD560 49] WindowsServer,
[2024.07.15-14.24.26:958][ 0]LogSerialization: Display: AllowBulkDataInIoStore: ‘true’
[2024.07.15-14.24.26:969][ 0]LogNetVersion: Icarus 1.0.0, NetCL: 0, EngineNetVer: 17, GameNetVer: 0 (Checksum: 1447163286)
[2024.07.15-14.24.26:991][ 0]LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
16:24:27
[2024.07.15-14.24.27:025][ 0]LogUObjectArray: 33243 objects as part of root set at end of initial load.
[2024.07.15-14.24.27:025][ 0]LogUObjectAllocator: 7037864 out of 0 bytes used by permanent object pool.
[2024.07.15-14.24.27:025][ 0]LogUObjectArray: CloseDisregardForGC: 33243/0 objects in disregard for GC pool
[2024.07.15-14.24.27:031][ 0]LogGauntlet: Display: Gauntlet Initialized
[2024.07.15-14.24.27:034][ 0]LogFMOD: Error: ‘FMOD::Debug_Initialize(FMOD_DEBUG_LEVEL_WARNING, FMOD_DEBUG_MODE_CALLBACK, FMODLogCallback)’ returned ‘A command issued was not supported by this object. Possibly a plugin without certain callbacks specified.’
[2024.07.15-14.24.27:042][ 0]LogFMOD: Error: ‘FMOD::Debug_Initialize(flags, FMOD_DEBUG_MODE_CALLBACK, FMODLogCallback)’ returned ‘A command issued was not supported by this object. Possibly a plugin without certain callbacks specified.’
[2024.07.15-14.24.27:042][ 0]IcarusOSSLog: SubsystemIcarus Startup!
[2024.07.15-14.24.27:042][ 0]LogSubstanceCoreModule: Substance [GPU] Engine Loaded, Max Texture Size = 8192
[2024.07.15-14.24.27:044][ 0]LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: PakFile ‘Z:/AMP/icarus/2089300/Icarus/Content/Data/data.pak’ (chunk index -1, root ‘../../../Icarus/Content/Data/’) mounted
[2024.07.15-14.24.27:044][ 0]LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: pending pak file info (ChunkID:-1 Root:../../../Icarus/Content/Data/ File:Z:/AMP/icarus/2089300/Icarus/Content/Data/data.pak)
[2024.07.15-14.24.27:062][ 0]EOSOSSLog: SubsystemEOS Startup!
[2024.07.15-14.24.27:064][ 0]LogAndroidPermission: UAndroidPermissionCallbackProxy::GetInstance
[2024.07.15-14.24.27:064][ 0]LogEngine: Initializing Engine…
[2024.07.15-14.24.27:069][ 0]LogStats: UGameplayTagsManager::InitializeManager - 0.005 s
[2024.07.15-14.24.27:078][ 0]LogInit: Initializing FReadOnlyCVARCache
[2024.07.15-14.24.27:078][ 0]LogNetVersion: Set ProjectVersion to 2.2.11.124669-rel-Laika. Version Checksum will be recalculated on next use.
[2024.07.15-14.24.27:078][ 0]LogInit: Texture streaming: Disabled
[2024.07.15-14.24.27:417][ 0]LogStreaming: Error: Couldn’t find file for package /Script/FunctionalTesting requested by async loading code. NameToLoad: /Script/FunctionalTesting
[2024.07.15-14.24.27:417][ 0]LogStreaming: Error: Found 1 dependent packages…
[2024.07.15-14.24.27:417][ 0]LogStreaming: Error: /Game/BP/Tools/CheatFunctions/CF_TakeScreenshotUI
[2024.07.15-14.24.27:629][ 0]LogProperty: Error: Struct type unknown for property ‘StructProperty /Game/BP/Tools/CheatFunctions/CF_TakeScreenshotUI.CF_TakeScreenshotUI_C:ExecuteUbergraph_CF_TakeScreenshotUI:K2Node_MakeStruct_AutomationScreenshotOptions’; perhaps the USTRUCT() was renamed or deleted?
[2024.07.15-14.24.27:629][ 0]LogProperty: Error: Struct type unknown for property ‘StructProperty /Game/BP/Tools/CheatFunctions/CF_TakeScreenshot.CF_TakeScreenshot_C:ExecuteUbergraph_CF_TakeScreenshot:K2Node_MakeStruct_AutomationScreenshotOptions’; perhaps the USTRUCT() was renamed or deleted?
16:24:28
[2024.07.15-14.24.28:630][ 0]IcarusUtilitiesLog: Warning: D_AssetReferences was unexpectedly requested for load, was expected to load during the ‘PostEngineInit’ phase
[2024.07.15-14.24.28:652][ 0]IcarusUtilitiesLog: Warning: D_PlayerTrackers was unexpectedly requested for load, was expected to load during the ‘PostContentServer’ phase
[2024.07.15-14.24.28:831][ 0]LogOnline: OSS: Creating online subsystem instance for: Icarus
[2024.07.15-14.24.28:831][ 0]IcarusOSSLog: Error: Login() failed: Empty Id
[2024.07.15-14.24.28:831][ 0]LogInit: Display: Game Engine Initialized.
16:24:33
[2024.07.15-14.24.33:310][ 0]IcarusUtilitiesLog: Warning: D_TalentTrees was unexpectedly requested for load, was expected to load during the ‘PostContentServer’ phase
16:24:38
[2024.07.15-14.24.38:010][ 0]LogNet: Display: SteamNetDriver_2147482103 bound to port 19132
[2024.07.15-14.24.38:010][ 0]PacketHandlerLog: Loaded PacketHandler component: Engine.EngineHandlerComponentFactory (StatelessConnectHandlerComponent)
[2024.07.15-14.24.38:010][ 0]PacketHandlerLog: Init Handler Complete - StatelessConnectHandlerComponent
[2024.07.15-14.24.38:010][ 0]PacketHandlerLog: All Handlers Initialised
[2024.07.15-14.24.38:010][ 0]LogNet: GameNetDriver SteamNetDriver_2147482103 IpNetDriver listening on port 19132
[2024.07.15-14.24.38:011][ 0]LogWorld: Bringing World /Game/Maps/DedicatedServerEntry.DedicatedServerEntry up for play (max tick rate 30) at 2024.07.15-14.24.38
[2024.07.15-14.24.38:012][ 0]LogWorld: Bringing up level for play took: 0.000411
[2024.07.15-14.24.38:012][ 0]LogGameMode: Display: Match State Changed from EnteringMap to WaitingToStart
[2024.07.15-14.24.38:012][ 0]LogLocalSessionSubsystem: Display: ResetActiveProspect - ProspectID: NULL | ProspectDTKey: NULL
[2024.07.15-14.24.38:013][ 0]LogContent: Pak meta checks passed.
[2024.07.15-14.24.38:013][ 0]LogDedicatedServerEntry: ------------------------------------------------
[2024.07.15-14.24.38:013][ 0]LogDedicatedServerEntry: – Dedicated server begin processing commands –
[2024.07.15-14.24.38:013][ 0]LogIcarusGameInstance: ====> Version: 2.2.11.124669-Shipping-Laika <====
[2024.07.15-14.24.38:013][ 0]LogDedicatedServerEntry: Attempting to create prospect: Outpost005_Forest
[2024.07.15-14.24.38:014][ 0]LogOnlineProspectManagement: RPC: GenerateProspects request
[2024.07.15-14.24.38:014][ 0]LogGameState: Match State Changed from EnteringMap to WaitingToStart
[2024.07.15-14.24.38:014][ 0]LogIcarusGameInstance: HandlePostLoadMap - WorldMapName: DedicatedServerEntry
[2024.07.15-14.24.38:014][ 0]LogLoad: Took 0.134803 seconds to LoadMap(/Game/Maps/DedicatedServerEntry)
[2024.07.15-14.24.38:014][ 0]LogInit: Display: Engine is initialized. Leaving FEngineLoop::Init()
[2024.07.15-14.24.38:014][ 0]LogLoad: (Engine Initialization) Total time: 12.13 seconds
[2024.07.15-14.24.38:014][ 0]LogIcarusGraphicsSettings: Warning: >> r.FidelityFX.FSR.Enabled is now: 0
[2024.07.15-14.24.38:014][ 0]LogIcarusGraphicsSettings: Warning: >> FSR Mode is now: 0
[2024.07.15-14.24.38:014][ 0]LogIcarusGraphicsSettings: >> ResolutionScale is now 100.000000 (0x0)
[2024.07.15-14.24.38:015][ 0]LogIcarusGraphicsSettings: Warning: >> r.VolumetricRenderTarget.Mode: 1 => 1
[2024.07.15-14.24.38:015][ 0]LogIcarusGraphicsSettings: Warning: >> r.VolumetricRenderTarget.UpsamplingMode: 4 => 4
[2024.07.15-14.24.38:015][ 0]LogIcarusGraphicsSettings: Warning: >> r.FidelityFX.FSR.Enabled is now: 0
[2024.07.15-14.24.38:015][ 0]LogIcarusGraphicsSettings: Warning: >> FSR Mode is now: 0
[2024.07.15-14.24.38:015][ 0]LogIcarusGraphicsSettings: Warning: >> r.FidelityFX.FSR.RCAS.Sharpness is now: 0.950000 => 0.2
[2024.07.15-14.24.38:015][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.RayTracing’ with ‘SetByGameSetting’ was ignored as it is lower priority than the previous ‘SetByProjectSetting’. Value remains ‘1’
[2024.07.15-14.24.38:015][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.RTXGI.DDGI’ with ‘SetByGameSetting’ was ignored as it is lower priority than the previous ‘SetByProjectSetting’. Value remains ‘true’
[2024.07.15-14.24.38:021][ 0]LogIcarusGraphicsSettings: Warning: >> AA Method is now: 2
[2024.07.15-14.24.38:021][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.Shadow.CSM.MaxCascades’ with ‘SetByScalability’ was ignored as it is lower priority than the previous ‘SetByGameSetting’. Value remains ‘2’
[2024.07.15-14.24.38:021][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.ContactShadows’ with ‘SetByScalability’ was ignored as it is lower priority than the previous ‘SetByGameSetting’. Value remains ‘1’
[2024.07.15-14.24.38:021][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.Streaming.LimitPoolSizeToVRAM’ with ‘SetByScalability’ was ignored as it is lower priority than the previous ‘SetByGameSetting’. Value remains ‘1’
[2024.07.15-14.24.38:021][ 0]LogConsoleManager: Warning: Setting the console variable ‘r.Streaming.PoolSize’ with ‘SetByScalability’ was ignored as it is lower priority than the previous ‘SetByGameSetting’. Value remains ‘4500’
[2024.07.15-14.24.38:115][ 0]LogUObjectHash: Compacting FUObjectHashTables data took 6.32ms
[2024.07.15-14.24.38:134][ 1]IcarusOSSLog: Error: OnResUserTicket : No player found
[2024.07.15-14.24.38:136][ 1]LogOnlineProspectManagement: Error: RPC: GenerateProspects response, OnResGenerateProspects was not bound to a response handler
[2024.07.15-14.24.38:136][ 1]LogOnlineProspectManagement: RPC: GenerateProspects response - Succeeded
Thanks for providing the log and system details!
First, let’s check the ports to see if they’re open and listening. Please run the following command in your terminal:
ampinstmgr ports [INSTANCENAME]
Replace [INSTANCENAME] with the name of your Icarus instance. This will help us verify if the ports are correctly configured.
Also, let’s make sure there are no firewall rules blocking the port. Run the following command:
ampinstmgr dumpfirewall
Let me know the output of these commands!
sudo -u amp ampinstmgr ports Icarus01
[Info/1] AMP Instance Manager v2.5.1 built 03/07/2024 19:18
[Info/1] Port usage for Icarus01 (Icarus)
[Info/1] Instance is currently running.
[Info/1] LISTENING 8090 TCP (Core.Webserver.Port)
[Info/1] LISTENING 2233 TCP (FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] CLOSED 19132 UDP (GenericModule.App.Ports.$GamePort)
[Info/1] LISTENING 27035 UDP (GenericModule.App.Ports.$QueryPort)
sudo ampinstmgr dumpfirewall
[Info/1] Using iptables firewall.
[Info/1] TCP/2223 (AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/12820 (AMP:ADS01:ADSModule.Network.MetricsServerPort)
[Info/1] TCP/2224 (AMP:SevenDaysToDie01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/27016 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ControlPanelPort)
[Info/1] UDP/27017 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$AdditionalPort)
[Info/1] TCP/27020 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$RemoteAdminPort)
[Info/1] TCP/2225 (AMP:Valheim01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/2227 (AMP:S7DTD-A2101:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/27024 (AMP:S7DTD-A2101:GenericModule.App.Ports.$ControlPanelPort)
[Info/1] UDP/27025 (AMP:S7DTD-A2101:GenericModule.App.Ports.$AdditionalPort)
[Info/1] TCP/27026 (AMP:S7DTD-A2101:GenericModule.App.Ports.$RemoteAdminPort)
[Info/1] TCP/2228 (AMP:ValheimKids01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/2229 (AMP:SonsForest01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/8766 (AMP:SonsForest01:GenericModule.App.Ports.$GamePort)
[Info/1] UDP/27027 (AMP:SonsForest01:GenericModule.App.Ports.$SteamQueryPort)
[Info/1] UDP/9876 (AMP:SonsForest01:GenericModule.App.Ports.$BlobSyncPort)
[Info/1] TCP/2231 (AMP:SevenDaysFall202301:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/27032 (AMP:SevenDaysFall202301:GenericModule.App.Ports.$ControlPanelPort)
[Info/1] TCP/27033 (AMP:SevenDaysFall202301:GenericModule.App.Ports.$RemoteAdminPort)
[Info/1] TCP/2226 (AMP:S7D2DDarknessFallsmanual01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/27019 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ServerPort1)
[Info/1] UDP/27021 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ServerPort2)
[Info/1] UDP/27022 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ServerPort3)
[Info/1] TCP/27028 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ControlPanelPort)
[Info/1] TCP/27029 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$RemoteAdminPort)
[Info/1] TCP/27030 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$AllocsModPort)
[Info/1] TCP/2230 (AMP:SchmeckelLand01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/2232 (AMP:SonsRelease01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/8767 (AMP:SonsRelease01:GenericModule.App.Ports.$GamePort)
[Info/1] UDP/27034 (AMP:SonsRelease01:GenericModule.App.Ports.$SteamQueryPort)
[Info/1] UDP/9877 (AMP:SonsRelease01:GenericModule.App.Ports.$BlobSyncPort)
[Info/1] TCP/27015 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort)
[Info/1] UDP/27015 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/2456 (AMP:Valheim01:GenericModule.App.ApplicationPort1)
[Info/1] UDP/2456 (AMP:Valheim01:GenericModule.App.ApplicationPort1)
[Info/1] TCP/2457 (AMP:Valheim01:GenericModule.App.ApplicationPort2)
[Info/1] UDP/2457 (AMP:Valheim01:GenericModule.App.ApplicationPort2)
[Info/1] TCP/27023 (AMP:S7DTD-A2101:GenericModule.App.Ports.$ServerPort)
[Info/1] UDP/27023 (AMP:S7DTD-A2101:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/2458 (AMP:ValheimKids01:GenericModule.App.ApplicationPort1)
[Info/1] UDP/2458 (AMP:ValheimKids01:GenericModule.App.ApplicationPort1)
[Info/1] TCP/2459 (AMP:ValheimKids01:GenericModule.App.ApplicationPort2)
[Info/1] UDP/2459 (AMP:ValheimKids01:GenericModule.App.ApplicationPort2)
[Info/1] TCP/27031 (AMP:SevenDaysFall202301:GenericModule.App.Ports.$ServerPort)
[Info/1] UDP/27031 (AMP:SevenDaysFall202301:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/27018 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ServerPort)
[Info/1] UDP/27018 (AMP:S7D2DDarknessFallsmanual01:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/15777 (AMP:SchmeckelLand01:GenericModule.App.Ports.$GamePort)
[Info/1] UDP/15777 (AMP:SchmeckelLand01:GenericModule.App.Ports.$GamePort)
[Info/1] TCP/15778 (AMP:SchmeckelLand01:GenericModule.App.Ports.$QueryPort)
[Info/1] UDP/15778 (AMP:SchmeckelLand01:GenericModule.App.Ports.$QueryPort)
[Info/1] TCP/2233 (AMP:Icarus01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] UDP/19132 (AMP:Icarus01:GenericModule.App.Ports.$GamePort)
[Info/1] UDP/27035 (AMP:Icarus01:GenericModule.App.Ports.$QueryPort)
Thanks for the detailed outputs! It looks like the game port (19132) is showing as closed. Let’s try restarting the Icarus instance to see if it helps.
You can restart the instance via the AMP web interface:
  1. Go to your AMP interface under the “ADS01” instance.
  2. Right-click on your Icarus instance.
  3. Select “Restart”.
Once the instance restarts, check if the ports are open again using the ampinstmgr ports [INSTANCENAME] command.
Let me know if the port status changes or if the problem persists!
Restarting the instance did not change the problem, deleting it and recreating it did lead to the same situation again. Should be easy to reproduce.
@CubeCoders-Bot Apollo, stop replying please.
@Bugslayer80_2 are you home hosting or is this on a rented server?
Home hosted on a Ubuntu 22.04.4 server.
I FOUND THE FIX. change the query port from 27015 to something else, i used 47015. I had this happen in another game, and tried it here and it worked as well~
