AMP does not open a port for the game. It will open all ports, but not the port to connect to the game. Also tried changing the port, but unsuccessfully. Problems are after the last update.
Installation
Run
Checking config files
Run server again
SFTP Port Number 2230 TCP
Main Server Port 27017 UDP
Query Dedicated Port 27018 UDP
AMP doesn’t ‘open’ ports - it’s reporting what the game server itself is doing. So for whatever reason the ETS2 server itself isn’t listening. Does a fresh instance with a fresh installation following the guide have the same problem?
