Connectivity Problem with Astroneer - Error in the Console (Linux)
Application Astroneer
ALSA lib confmisc.c:855:(parse_card) cannot find card ‘0’
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM default
  • Setting to seperate Docker
  • update the instance
  • Error in Console
That’s actually an audio related error.
Thank you! I found out myself after some time, but no idea how to disable it…
I’m actually deploying now, will look as well (not familiar with the game but two sets of eyes and all that)
The server stays running, despite the alsa lib vomit. I assume you can’t connect to it?
yes, it stays running but I can’t connect to it
Yeah, looks like it might require the flag winetricks sound=alsa be added to the image (still newer to this, so I believe staff manage the upstream)
Are you using your public IP in the client? Astroneer requires it
Ignore the ALSA stuff
uhh, yes im using the puplic IP, but still can’t connect
From inside your own network? Try from outside your network (such as on a phone hotspot). I assume you are home hosting and have port forwarded?
uhm… im not home hosting…
OK, if you want help, how about providing proper info rather than sarcastic responses? How the hell do I know your setup?
Sorry, my fault, im a little bit stupid, but thx for your help !
