Connectivity Problem with Astroneer - Astroneer server problems
Operating System Windows - Windows Server 2019 on x86_64
Product AMP ‘Decadeus’ v2.4.6.0 (Mainline)
Virtualization Xen
Application Astroneer
It seems the current AMP config for astroneer doesn’t work, I had to get the instance working by manually adding stuff to the config, in engine.ini
  • Restart Instance
  • Go into server windowsserver settings
  • Open up and edit engine.ini, add [URL] port=8777
The template assumes that ports can be set by command line args. Seems that is no longer the case?
Will check it out
The template has been fixed. Right click on your instance, Refresh Configuration (assuming standalone AMP installation)
