Connectivity Problem with Astroneer - Astroneer connectivity issues
Product AMP ‘Callisto’ v2.5.1.4 (Mainline)
Application Astroneer
I tried both on the default port of 7777 and 8777. I tried connecting through my local network and online. I have no issues with Valheim or Minecraft hosting, but can’t seem to get this to work.
  • Add server IP in astroneer client
  • server is displayed and proceed to connect
  • Joining host displayed for a time, then failed to connect to host displayed
You have to use your public IP (which means you need to port forward and have a router that supports NAT hairpin), and have to configure the client to disable encryption as per the info box in the AMP settings
Cheers, worked a treat.
I pressed Win + R and typed %LocalAppData%/Astro/Saved/Config/WindowsNoEditor
Then I edited Engine.ini in notepad and added this to the bottom
[SystemSettings]
net.AllowEncryption=False
Then in Astroneer I added my IP address as a server.
