Connectivity Problem with ARK: Survival Evolved - Cannot Connect To Server - ArkSurvivalEvolved
Operating System Linux - Ubuntu 20.04.6 on x86_64
Product AMP ‘Decadeus’ v2.4.5.4 (Mainline)
Virtualization VMware
Application ARK: Survival Evolved
As title says, I have set it up and checked that the ports were open using dumpfirewall and checking ufw status (there is one which is closed called the ReservedPort i’m not sure if this is the reason?) but yeah cannot connect or find server information
  • Start + Update Instance
  • Tried Direct Connect - Server not found
  • Tried Game Server Manager In Steam - Server not found
Is this home hosted or on a dedicated server?
Hi MIke,
Thanks for the quick response,
It’s on a dedicated server, a VPS through Fasthosts
Thanks,
Olly
Have you checked using ampinstmgr ports (run as the amp user) that the requisite ports are showing as listening?
Yeah I did check using the ampinstmgr ports, it showed all as open except from the reserved port which was closed
Check that there is no FastHosts firewall you need to configure: Managing Firewall Policy rules for your Dedicated and Virtual Private Servers
Also suggest it is worth your reading this guide: ARK: Survival Evolved Guide
I have now read through all of the ARK: Survival Evolved Guide and ensured that there is no Firewall settings for FastHosts that are getting in the way (they’re all open on FastHosts and switched to be controlled by ufw)
Still showing as “Server is not responding” on steam unfortunately
What port are you using in Steam? Have to use the query port
