Connectivity Problem with Application Deployment - Unable to Login to my Minecraft Server
Virtualization QEMU_KVM
Unable to connect to Minecraft server hosted on VPS
  • Could not connect to Minecraft Server - Game/Server not the same version
  • Updated the server instance to latest version
  • Cannot connect to Minecraft server, instead of error connection just holds until it times out
  • Tried restarting instance, restarting amp, and updating amp - none of these steps solved the problem
Are you sure you have the latest version as you mention; what is the version number, what mod if any are you using and what is your local client version? Also have you verified that iptables is configured correctly?
I honestly am not sure how to check the Minecraft server version so that’s possible. The AMP is v2.4.6.10. I just hit update for both the server instance and the AMP instance. Do you know how to check? I can see my Minecraft client version is 1.20.50
I haven’t messed with the IP tables, but did double check the IP/Ports are correct. I can ping the server via Minecraft, they show there, with low ping. But when joining it just hangs until it times out.
Thank you for your assistance
are you trying to host bedrock edition?
Yes, it’s Bedrock.
For context, I’ve been using this server without issue for the last ~2 months. With the recent Minecraft version update, I needed to update the server. After hitting update in the Game Panel these issues appeared.
SSH into your server and go to your amp user with:
sudo su -l amp Then we are going to switch your bedrock instance to Development branch: ampinstmgr switch instancename Development
replacing instancename with the actual name of the instance in AMP.
Then we are going to update your instance with ampinstmgr upgrade instancename
Thanks @ssfdre38 - All steps completed, no change.
Additional context, I have 2 servers/instances on my AMP. Both Minecraft: Bedrock servers. They both behave the same way.
I did the steps you mentioned for 1 of the two servers, but still no luck =(
sometime you have to restart the instance for it to take so on the main part of the panel just stop the instance and wait like 10 seconds and then start it up again
The instance stopped, then started, no success. I had previously restarted, updated, etc. with no luck as well.
can you send me your log on here?
Sure which log? The AMP? The instance? PS. Not sure those logs are what you’re asking for - they only have super high level stuff like log in attempts?
PS. I tried creating a brand new bedrock instance - cannot connect to that either - same issue.
PSS. I’ve tried logging on from two diff computers, so pretty sure it’s not the Minecraft client
PSSS. I tried restarting the VPS too, no luck
the amp log so i can see what is going on. you can remove anything that shouldn’t be seen
Scraped it, don’t think anything of risk to post publicly (I guess my server IP is there)… let me know if you think I should redact anything for security
admin 12/9/2023, 10:44:36 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 10:44:36 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
admin 12/9/2023, 10:44:35 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 10:44:35 AM Logger LogLevels.Activity Managed remote instance MoleWorld01 at :8082/
admin 12/9/2023, 10:44:15 AM Logger LogLevels.Activity Upgrading instance MoleWorld01
admin 12/9/2023, 10:41:26 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 10:41:26 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
admin 12/9/2023, 10:41:26 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 10:41:26 AM Logger LogLevels.Activity Managed remote instance MoleWorld01 at :8082/
admin 12/9/2023, 10:31:08 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 10:31:08 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
admin 12/9/2023, 10:31:08 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 10:31:08 AM Logger LogLevels.Activity Managed remote instance MoleWorld01 at :8082/
admin 12/9/2023, 10:27:20 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 10:27:20 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via 62a4161d-c451-4dd1-ac82-af639fcd459b
admin 12/9/2023, 10:27:19 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 10:27:19 AM Logger LogLevels.Activity Managed remote instance MolemanTheReturn01 at :8083/
admin 12/9/2023, 10:25:57 AM InstanceManagerPlugin IMAuditEvents.CreateInstance Created instance MolemanTheReturn01 using Minecraft module on port 8083.
admin 12/9/2023, 10:25:30 AM Logger LogLevels.Activity Deleting instance 458c081d-6e71-4102-8c9e-1b0ab009d722
admin 12/9/2023, 9:09:02 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 9:09:02 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 23.243.139.188 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36)
admin 12/9/2023, 8:39:09 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 8:39:08 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
admin 12/9/2023, 8:39:08 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 8:39:08 AM Logger LogLevels.Activity Managed remote instance MoleWorld01 at :8082/
admin 12/9/2023, 8:38:46 AM Authentication AuthAuditEvents.LoginSuccess
admin 12/9/2023, 8:38:46 AM Authentication AuthAuditEvents.LoginAttempt Login attempt from 193.203.164.239 (CCL/AMPAPI) via 458c081d-6e71-4102-8c9e-1b0ab009d722
admin 12/9/2023, 8:38:46 AM Logger LogLevels.Activity Authentication token for admin requested by ManageInstance on behalf of admin
admin 12/9/2023, 8:38:46 AM Logger LogLevels.Activity Managed remote instance MoleManTheReturn01 at :8083/
admin 12/9/2023, 8:38:25 AM Authentication AuthAuditEvents.LoginSuccess
right click on your bedrock instance and then go to view logs and show the latest log there
[00:00:00] [Logger Info] : Rollover from previous log file: AMP_Logs/AMPLOG 2023-11-10 00-00-00.log
[00:03:27] [INFO]: Running AutoCompaction…
[00:09:27] [INFO]: Running AutoCompaction…
[00:15:27] [INFO]: Running AutoCompaction…
[00:21:27] [INFO]: Running AutoCompaction…
[00:27:27] [INFO]: Running AutoCompaction…
[00:33:27] [INFO]: Running AutoCompaction…
[00:39:27] [INFO]: Running AutoCompaction…
[00:45:27] [INFO]: Running AutoCompaction…
[00:50:00] [Core Info] : Checking for AMP updates…
[00:50:00] [Core Info] : AMP is up to date.
[00:51:27] [INFO]: Running AutoCompaction…
[00:57:27] [INFO]: Running AutoCompaction…
[01:03:27] [INFO]: Running AutoCompaction…
[01:09:27] [INFO]: Running AutoCompaction…
[01:15:27] [INFO]: Running AutoCompaction…
[01:21:27] [INFO]: Running AutoCompaction…
[01:27:27] [INFO]: Running AutoCompaction…
[01:33:27] [INFO]: Running AutoCompaction…
[01:39:27] [INFO]: Running AutoCompaction…
[01:45:27] [INFO]: Running AutoCompaction…
[01:51:27] [INFO]: Running AutoCompaction…
[01:57:27] [INFO]: Running AutoCompaction…
[02:03:27] [INFO]: Running AutoCompaction…
[02:09:27] [INFO]: Running AutoCompaction…
[02:15:27] [INFO]: Running AutoCompaction…
[02:21:27] [INFO]: Running AutoCompaction…
[02:27:27] [INFO]: Running AutoCompaction…
[02:33:27] [INFO]: Running AutoCompaction…
[02:39:27] [INFO]: Running AutoCompaction…
[02:45:27] [INFO]: Running AutoCompaction…
[02:51:27] [INFO]: Running AutoCompaction…
[02:57:27] [INFO]: Running AutoCompaction…
[03:03:27] [INFO]: Running AutoCompaction…
[03:09:27] [INFO]: Running AutoCompaction…
[03:15:27] [INFO]: Running AutoCompaction…
[03:21:27] [INFO]: Running AutoCompaction…
[03:27:27] [INFO]: Running AutoCompaction…
[03:33:27] [INFO]: Running AutoCompaction…
[03:39:27] [INFO]: Running AutoCompaction…
[03:45:27] [INFO]: Running AutoCompaction…
[03:51:27] [INFO]: Running AutoCompaction…
[03:57:27] [INFO]: Running AutoCompaction…
[04:03:27] [INFO]: Running AutoCompaction…
[04:09:27] [INFO]: Running AutoCompaction…
[04:15:27] [INFO]: Running AutoCompaction…
[04:21:27] [INFO]: Running AutoCompaction…
[04:27:27] [INFO]: Running AutoCompaction…
[04:33:27] [INFO]: Running AutoCompaction…
[04:39:27] [INFO]: Running AutoCompaction…
[04:45:27] [INFO]: Running AutoCompaction…
[04:51:27] [INFO]: Running AutoCompaction…
[04:55:02] [INFO]: Player connected: Aeth0000, xuid: 2535409974249021
[04:55:04] [INFO]: Player Spawned: Aeth0000 xuid: 2535409974249021, pfid: 977d95238e8920c3
[05:01:07] [INFO]: Running AutoCompaction…
[05:07:11] [INFO]: Running AutoCompaction…
[05:13:39] [INFO]: Running AutoCompaction…
[05:19:48] [INFO]: Running AutoCompaction…
[05:26:30] [INFO]: Running AutoCompaction…
[05:33:12] [INFO]: Running AutoCompaction…
[05:40:04] [INFO]: Running AutoCompaction…
[05:56:04] [INFO]: Running AutoCompaction…
[06:02:19] [INFO]: Running AutoCompaction…
[06:08:51] [INFO]: Running AutoCompaction…
[06:20:50] [INFO]: Running AutoCompaction…
[06:27:28] [INFO]: Running AutoCompaction…
[06:34:13] [INFO]: Running AutoCompaction…
[06:40:23] [INFO]: Running AutoCompaction…
[06:47:19] [INFO]: Running AutoCompaction…
[06:49:26] [INFO]: Player disconnected: Aeth0000, xuid: 2535409974249021, pfid: 977d95238e8920c3
[06:50:00] [Core Info] : Checking for AMP updates…
[06:50:00] [Core Info] : AMP is up to date.
[06:54:04] [INFO]: Running AutoCompaction…
[07:00:04] [INFO]: Running AutoCompaction…
[07:06:04] [INFO]: Running AutoCompaction…
[07:12:04] [INFO]: Running AutoCompaction…
[07:18:04] [INFO]: Running AutoCompaction…
[07:24:04] [INFO]: Running AutoCompaction…
[07:30:04] [INFO]: Running AutoCompaction…
[07:36:04] [INFO]: Running AutoCompaction…
[07:42:04] [INFO]: Running AutoCompaction…
[07:48:04] [INFO]: Running AutoCompaction…
[07:54:04] [INFO]: Running AutoCompaction…
[08:00:04] [INFO]: Running AutoCompaction…
[08:06:04] [INFO]: Running AutoCompaction…
[08:12:04] [INFO]: Running AutoCompaction…
[08:18:04] [INFO]: Running AutoCompaction…
[08:24:04] [INFO]: Running AutoCompaction…
[08:30:04] [INFO]: Running AutoCompaction…
[08:36:04] [INFO]: Running AutoCompaction…
[08:42:04] [INFO]: Running AutoCompaction…
[08:48:04] [INFO]: Running AutoCompaction…
[08:54:04] [INFO]: Running AutoCompaction…
[09:00:04] [INFO]: Running AutoCompaction…
[09:06:04] [INFO]: Running AutoCompaction…
[09:12:04] [INFO]: Running AutoCompaction…
[09:18:04] [INFO]: Running AutoCompaction…
[09:24:04] [INFO]: Running AutoCompaction…
[09:30:04] [INFO]: Running AutoCompaction…
[09:36:04] [INFO]: Running AutoCompaction…
[09:42:04] [INFO]: Running AutoCompaction…
[09:48:04] [INFO]: Running AutoCompaction…
[09:54:04] [INFO]: Running AutoCompaction…
[10:00:04] [INFO]: Running AutoCompaction…
[10:06:04] [INFO]: Running AutoCompaction…
[10:12:04] [INFO]: Running AutoCompaction…
[10:18:04] [INFO]: Running AutoCompaction…
[10:24:04] [INFO]: Running AutoCompaction…
[10:30:04] [INFO]: Running AutoCompaction…
[10:36:04] [INFO]: Running AutoCompaction…
[10:42:04] [INFO]: Running AutoCompaction…
[10:48:04] [INFO]: Running AutoCompaction…
[10:54:04] [INFO]: Running AutoCompaction…
[11:00:04] [INFO]: Running AutoCompaction…
[11:06:04] [INFO]: Running AutoCompaction…
[11:12:04] [INFO]: Running AutoCompaction…
[11:18:04] [INFO]: Running AutoCompaction…
[11:24:05] [INFO]: Running AutoCompaction…
[11:30:05] [INFO]: Running AutoCompaction…
[11:36:05] [INFO]: Running AutoCompaction…
[11:42:05] [INFO]: Running AutoCompaction…
[11:48:05] [INFO]: Running AutoCompaction…
[11:54:05] [INFO]: Running AutoCompaction…
[12:00:05] [INFO]: Running AutoCompaction…
[12:06:05] [INFO]: Running AutoCompaction…
[12:12:05] [INFO]: Running AutoCompaction…
[12:18:05] [INFO]: Running AutoCompaction…
[12:24:05] [INFO]: Running AutoCompaction…
[12:30:05] [INFO]: Running AutoCompaction…
[12:36:05] [INFO]: Running AutoCompaction…
[12:42:05] [INFO]: Running AutoCompaction…
[12:48:05] [INFO]: Running AutoCompaction…
[12:50:00] [Core Info] : Checking for AMP updates…
[12:50:00] [Core Info] : AMP is up to date.
[12:54:05] [INFO]: Running AutoCompaction…
[13:00:05] [INFO]: Running AutoCompaction…
[13:06:05] [INFO]: Running AutoCompaction…
[13:12:05] [INFO]: Running AutoCompaction…
[13:18:05] [INFO]: Running AutoCompaction…
[13:24:05] [INFO]: Running AutoCompaction…
[13:30:05] [INFO]: Running AutoCompaction…
[13:36:05] [INFO]: Running AutoCompaction…
[13:42:05] [INFO]: Running AutoCompaction…
[13:48:05] [INFO]: Running AutoCompaction…
[13:54:05] [INFO]: Running AutoCompaction…
[14:00:05] [INFO]: Running AutoCompaction…
[14:06:05] [INFO]: Running AutoCompaction…
[14:12:05] [INFO]: Running AutoCompaction…
[14:18:05] [INFO]: Running AutoCompaction…
[14:24:05] [INFO]: Running AutoCompaction…
[14:30:05] [INFO]: Running AutoCompaction…
[14:36:05] [INFO]: Running AutoCompaction…
[14:42:05] [INFO]: Running AutoCompaction…
[14:48:05] [INFO]: Running AutoCompaction…
[14:54:05] [INFO]: Running AutoCompaction…
[15:00:05] [INFO]: Running AutoCompaction…
[15:06:05] [INFO]: Running AutoCompaction…
[15:12:05] [INFO]: Running AutoCompaction…
[15:18:05] [INFO]: Running AutoCompaction…
[15:24:05] [INFO]: Running AutoCompaction…
[15:30:05] [INFO]: Running AutoCompaction…
[15:36:05] [INFO]: Running AutoCompaction…
[15:42:05] [INFO]: Running AutoCompaction…
[15:48:05] [INFO]: Running AutoCompaction…
[15:54:05] [INFO]: Running AutoCompaction…
[16:00:05] [INFO]: Running AutoCompaction…
[16:06:05] [INFO]: Running AutoCompaction…
[16:12:05] [INFO]: Running AutoCompaction…
[16:18:05] [INFO]: Running AutoCompaction…
[16:24:05] [INFO]: Running AutoCompaction…
[16:30:05] [INFO]: Running AutoCompaction…
[16:36:05] [INFO]: Running AutoCompaction…
[16:42:05] [INFO]: Running AutoCompaction…
[16:48:05] [INFO]: Running AutoCompaction…
[16:54:05] [INFO]: Running AutoCompaction…
[17:00:05] [INFO]: Running AutoCompaction…
[17:06:05] [INFO]: Running AutoCompaction…
[17:12:05] [INFO]: Running AutoCompaction…
[17:18:05] [INFO]: Running AutoCompaction…
[17:24:05] [INFO]: Running AutoCompaction…
[17:30:05] [INFO]: Running AutoCompaction…
[17:36:05] [INFO]: Running AutoCompaction…
[17:42:05] [INFO]: Running AutoCompaction…
[17:48:05] [INFO]: Running AutoCompaction…
[17:54:05] [INFO]: Running AutoCompaction…
[18:00:05] [INFO]: Running AutoCompaction…
[18:06:05] [INFO]: Running AutoCompaction…
[18:12:05] [INFO]: Running AutoCompaction…
[18:18:05] [INFO]: Running AutoCompaction…
[18:24:05] [INFO]: Running AutoCompaction…
[18:30:05] [INFO]: Running AutoCompaction…
[18:36:05] [INFO]: Running AutoCompaction…
[18:42:05] [INFO]: Running AutoCompaction…
[18:48:05] [INFO]: Running AutoCompaction…
[18:50:00] [Core Info] : Checking for AMP updates…
[18:50:00] [Core Info] : AMP is up to date.
[18:54:05] [INFO]: Running AutoCompaction…
[19:00:05] [INFO]: Running AutoCompaction…
[19:06:05] [INFO]: Running AutoCompaction…
[19:12:05] [INFO]: Running AutoCompaction…
[19:18:05] [INFO]: Running AutoCompaction…
[19:24:05] [INFO]: Running AutoCompaction…
[19:30:05] [INFO]: Running AutoCompaction…
[19:36:05] [INFO]: Running AutoCompaction…
[19:42:05] [INFO]: Running AutoCompaction…
[19:48:05] [INFO]: Running AutoCompaction…
[19:54:05] [INFO]: Running AutoCompaction…
[20:00:05] [INFO]: Running AutoCompaction…
[20:06:05] [INFO]: Running AutoCompaction…
[20:12:05] [INFO]: Running AutoCompaction…
[20:18:05] [INFO]: Running AutoCompaction…
[20:24:05] [INFO]: Running AutoCompaction…
[20:30:05] [INFO]: Running AutoCompaction…
[20:36:05] [INFO]: Running AutoCompaction…
[20:42:05] [INFO]: Running AutoCompaction…
[20:48:05] [INFO]: Running AutoCompaction…
[20:54:05] [INFO]: Running AutoCompaction…
[21:00:05] [INFO]: Running AutoCompaction…
[21:06:05] [INFO]: Running AutoCompaction…
[21:12:05] [INFO]: Running AutoCompaction…
[21:18:05] [INFO]: Running AutoCompaction…
[21:24:05] [INFO]: Running AutoCompaction…
[21:30:05] [INFO]: Running AutoCompaction…
[21:36:05] [INFO]: Running AutoCompaction…
[21:42:05] [INFO]: Running AutoCompaction…
[21:48:06] [INFO]: Running AutoCompaction…
[21:54:06] [INFO]: Running AutoCompaction…
[22:00:06] [INFO]: Running AutoCompaction…
[22:06:06] [INFO]: Running AutoCompaction…
[22:12:06] [INFO]: Running AutoCompaction…
[22:18:06] [INFO]: Running AutoCompaction…
[22:24:06] [INFO]: Running AutoCompaction…
[22:30:06] [INFO]: Running AutoCompaction…
[22:36:06] [INFO]: Running AutoCompaction…
[22:42:06] [INFO]: Running AutoCompaction…
[22:48:06] [INFO]: Running AutoCompaction…
[22:54:06] [INFO]: Running AutoCompaction…
[23:00:06] [INFO]: Running AutoCompaction…
[23:00:49] [INFO]: Player connected: Aeth0000, xuid: 2535409974249021
[23:01:03] [INFO]: Player Spawned: Aeth0000 xuid: 2535409974249021, pfid: 977d95238e8920c3
[23:06:57] [INFO]: Running AutoCompaction…
[23:13:09] [INFO]: Running AutoCompaction…
[23:27:14] [INFO]: Running AutoCompaction…
[23:33:32] [INFO]: Running AutoCompaction…
[23:39:53] [INFO]: Running AutoCompaction…
[23:46:04] [INFO]: Running AutoCompaction…
[23:46:19] [INFO]: Player disconnected: Aeth0000, xuid: 2535409974249021, pfid: 977d95238e8920c3
[23:46:27] [INFO]: Player connected: Aeth0000, xuid: 2535409974249021
[23:46:40] [INFO]: Player Spawned: Aeth0000 xuid: 2535409974249021, pfid: 977d95238e8920c3
[23:52:14] [INFO]: Running AutoCompaction…
[23:53:43] [INFO]: Player disconnected: Aeth0000, xuid: 2535409974249021, pfid: 977d95238e8920c3
[23:58:25] [INFO]: Running AutoCompaction…
can you show the other logs too cause this is a roll over i just want to see what is going on
PS. The bedrock server where this all started now won’t even start. I get this message
The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
The other server (pre-existing) is running, can ping, but not join. The brand new server I created for testing is running, can ping, but not join.
Log info
[17:02:39] [Logger Info] : Starting AMP version 2.4.6.10 (Decadeus), built 06/12/2023 17:17
[17:02:39] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[17:02:40] [Logger Info] : Running in a QEMU KVM environment.
[17:02:40] [Logger Info] : Purging old audit logs (this may take a moment)…
[17:02:40] [Logger Info] : OS: Linux / x86_64
[17:02:40] [Logger Info] : CPU: AMD EPYC 7543P 32-Core Processor (1C/1T)
[17:02:40] [Logger Info] : RAM: 3934MB
[17:02:40] [Logger Info] : AMP Instance ID: ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
[17:02:43] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[17:02:43] [Logger Info] : Metrics publishing is enabled at udp://193.203.164.239:12820.
[17:02:43] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[17:02:43] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[17:02:43] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[17:02:43] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[17:02:44] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[17:02:45] [Logger Info] : Licence Present: AMP Enterprise Edition
[17:02:48] [Logger Notice] : Using keypair with fingerprint +ZqFQNvQgRjYTEmb6jgkNMWeaRIW8GYJCWRdTSi7Xe8=
[17:02:48] [Logger Info] : SFTP Server started on 193.203.164.239:2225
[17:02:48] [Webserver Info] : Websockets are enabled.
[17:02:49] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[17:02:49] [Logger Info] : Webserver started on ://193.203.164.239:8082
[17:02:49] [Core Info] : Checking for AMP updates…
[17:02:49] [Logger Info] : Startup mode is UpdateAndStart.
[17:02:50] [Core Info] : AMP is up to date.
[17:02:50] [Logger Warning] : Unable to get Bedrock version data from .minecraft.net/en-us/download/server/bedrock: Data not found.
[17:02:51] [Logger Info] : Modpack cache is up-to-date.
[17:03:05] NO LOG FILE! - setting up server logging…
[17:03:05] [INFO]: Starting Server
[17:03:05] [INFO]: Version 1.17.10.04
[17:03:05] [INFO]: Session ID 16c5ba06-b70b-4443-bd8d-72f5da9b892e
[17:03:05] [INFO]: Level Name: world
[17:03:05] [INFO]: Game mode: 0 Survival
[17:03:05] [INFO]: Difficulty: 2 NORMAL
[17:03:08] [INFO]: opening worlds/world/db
[17:03:16] [INFO]: IPv4 supported, port: 0
[17:03:16] [INFO]: IPv6 supported, port: 0
[17:03:16] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[17:03:16] Version: 1.17.10.04
[17:03:16] OS: Linux
[17:03:16] Server start: 2023-12-09 17:03:05 UTC
[17:03:16] Dmp timestamp: 2023-12-09 17:03:16 UTC
[17:03:16] Upload Date: 2023-12-09 17:03:16 UTC
[17:03:16] Session ID: 16c5ba06-b70b-4443-bd8d-72f5da9b892e
[17:03:16] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[17:03:16] Build id: 6472255
[17:03:16] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[17:03:16] Crash
[17:03:16] [INFO]
[17:03:16] Failed to open curl lib from binary, use libcurl.so instead
[17:03:17] 79235a18-35b4-4610-858a-3c09e8506454
[17:03:17] [Logger Warning] : Server failed to start 1/5 times…
[17:03:17] [Logger Warning] : The application stopped unexpectedly. Exit code 1
[17:03:17] [Logger Error] : Unable to start Minecraft Server
[17:03:17] [Core Error] : PlatformException
[17:03:17] [Logger Error] : [0] (PlatformException) : ApplicationName=‘./Minecraft/bedrock_server’, CommandLine=‘’, CurrentDirectory=‘./Minecraft/’, Native error= Cannot find the specified file
[17:03:17] [Core Error] : at Diagnostics.Process.StartWithCreateProcess (Diagnostics.ProcessStartInfo startInfo)
at Diagnostics.Process.Start ()
at ModuleShared.AMPProcess.Start ()
at (wrapper remoting-invoke-with-check) ModuleShared.AMPProcess.Start()
at MinecraftModule.MinecraftApp.StartGameServer (Boolean autoRetry)
[18:17:54] [Logger Info] : Stop requested: SIGUSR1 Recieved
[18:17:54] [Core Notice] : AMP shutdown requested.
[18:17:54] [Core Notice] : Stopping Application…
[18:17:54] [Minecraft Info] : Application stop requested
[18:17:54] [Minecraft Error] : Failed to write to Minecraft server STDIN stream. Server process will be killed (if it isn’t already dead)
[18:17:54] [Core Error] : InvalidOperationException
[18:17:54] [Logger Error] : [0] (InvalidOperationException) : StandardIn has not been redirected.
[18:17:54] [Core Error] : at Diagnostics.Process.get_StandardInput ()
at (wrapper remoting-invoke-with-check) Diagnostics.Process.get_StandardInput()
at MinecraftModule.MinecraftApp.WriteLine (String message)
[18:17:54] [Core Notice] : Stopping Web Server…
[18:17:54] [Webserver Info] : Web server shutdown.
[18:17:54] [Core Notice] : Goodbye!
Rest in peace - Stephen Hawking 1942-2018
I miss you Casper. <3
[18:18:46] [Logger Info] : Starting AMP version 2.4.6.10 (Decadeus), built 09/12/2023 08:32
[18:18:46] [Logger Info] : Stream: Development / Development - built by CUBECODERS/buildbot on CCL-DEV
[18:18:46] [Logger Info] : Running in a QEMU KVM environment.
[18:18:46] [Logger Info] : Purging old audit logs (this may take a moment)…
[18:18:46] [Logger Info] : OS: Linux / x86_64
[18:18:46] [Logger Info] : CPU: AMD EPYC 7543P 32-Core Processor (1C/1T)
[18:18:46] [Logger Info] : RAM: 3934MB
[18:18:46] [Logger Info] : AMP Instance ID: ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
[18:18:46] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[18:18:46] [Logger Info] : Metrics publishing is enabled at udp://193.203.164.239:12820.
[18:18:46] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[18:18:46] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:18:46] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[18:18:47] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:18:47] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[18:18:47] [Logger Info] : Licence Present: AMP Enterprise Edition
[18:18:48] [Logger Notice] : Using keypair with fingerprint +ZqFQNvQgRjYTEmb6jgkNMWeaRIW8GYJCWRdTSi7Xe8=
[18:18:48] [Logger Info] : SFTP Server started on 193.203.164.239:2225
[18:18:48] [Webserver Info] : Websockets are enabled.
[18:18:48] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[18:18:48] [Logger Info] : Webserver started on ://193.203.164.239:8082
[18:18:48] [Core Info] : Checking for AMP updates…
[18:18:48] [Logger Info] : Startup mode is UpdateAndStart.
[18:18:49] [Core Info] : AMP is up to date.
[18:19:19] [Logger Warning] : Unable to get Bedrock version data from .minecraft.net/en-us/download/server/bedrock
[18:19:19] [Core Error] : TaskCanceledException
[18:19:19] [Logger Error] : [0] (TaskCanceledException) : The operation was canceled.
[18:19:19] [Core Error] : at MinecraftModule.UpdateManager.GetBedrockVersion ()
[18:19:19] [Core Error] : ObjectDisposedException
[18:19:19] [Logger Error] : [1] (ObjectDisposedException) : Cannot access a disposed object.
Object name: ‘MobileAuthenticatedStream’.
[18:19:19] [Core Error] : at Net.Http.HttpConnection.FillAsync ()
at Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync (Boolean foldedHeadersAllowed)
[18:19:19] [Minecraft Info] : Trying first Bedrock info fallback…
[18:19:24] [Logger Info] : Latest Bedrock version: 1.20.50.03
[18:19:25] [Logger Info] : Modpack cache is up-to-date.
[18:19:34] NO LOG FILE! - setting up server logging…
[18:19:34] [INFO]: Starting Server
[18:19:34] [INFO]: Version 1.17.10.04
[18:19:34] [INFO]: Session ID cc3d3e44-8856-495b-acaa-bf8ea8c0c93e
[18:19:34] [INFO]: Level Name: world
[18:19:34] [INFO]: Game mode: 0 Survival
[18:19:34] [INFO]: Difficulty: 2 NORMAL
[18:19:34] [INFO]: opening worlds/world/db
[18:19:35] [INFO]: IPv4 supported, port: 0
[18:19:35] [INFO]: IPv6 supported, port: 0
[18:19:35] Failed to open curl lib from binary, use libcurl.so instead
[18:19:35] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[18:19:35] Version: 1.17.10.04
[18:19:35] OS: Linux
[18:19:35] Server start: 2023-12-09 18:19:34 UTC
[18:19:35] Dmp timestamp: 2023-12-09 18:19:35 UTC
[18:19:35] Upload Date: 2023-12-09 18:19:35 UTC
[18:19:35] Session ID: cc3d3e44-8856-495b-acaa-bf8ea8c0c93e
[18:19:35] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[18:19:35] Build id: 6472255
[18:19:35] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[18:19:35] Crash
[18:19:35] [INFO]
[18:19:36] c4692f4c-3a08-4e48-a787-a5509813e49f
[18:19:36] [Logger Warning] : Server failed to start 1/5 times…
[18:19:36] [Logger Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[18:31:08] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[18:31:09] [Core Activity] : Authentication success
[18:41:26] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[18:41:26] [Core Activity] : Authentication success
[18:42:05] [API:admin Activity] : Updating the application.
[18:42:31] [API:admin Activity] : Starting the application.
[18:42:31] NO LOG FILE! - setting up server logging…
[18:42:31] [INFO]: Starting Server
[18:42:31] [INFO]: Version: 1.20.50.03
[18:42:31] [INFO]: Session ID: 23614282-cf96-455d-b4f9-e0a87dba09f7
[18:42:31] [INFO]: Build ID: 19782165
[18:42:31] [INFO]: Branch: r/20_u5
[18:42:31] [INFO]: Commit ID: e6d2c18ba9d27b694621a3d69c8114aaf1bd64ac
[18:42:31] [INFO]: Configuration: Publish
[18:42:31] [INFO]: Level Name: world
[18:42:31] [INFO]: No CDN config file found for dedicated server
[18:42:31] [INFO]: Game mode: 0 Survival
[18:42:31] [INFO]: Difficulty: 2 NORMAL
[18:42:31] [INFO]: Content logging to console is enabled.
[18:42:31] [2023-12-09 18:42:31:458 ERROR]: The following issues were found when loading packs:
[18:42:31] behavior_packs/vanilla_gametest
[18:42:31] Provided ‘/modules/0/type’ element has an invalid value in pack manifest.
[18:42:31] [INFO]: Opening level ‘worlds/world/db’
[18:42:32] [2023-12-09 18:42:32:041 ERROR]: Port [19133] may be in use by another process. Free up port and re-run program or adjust server.properties file to use alternate ports for server
[18:42:32] [2023-12-09 18:42:32:044 ERROR]: Port [19134] may be in use by another process. Free up port and re-run program or adjust server.properties file to use alternate ports for server
[18:42:32] [2023-12-09 18:42:32:044 ERROR]: Exiting program
[18:42:32] [Logger:admin Warning] : Server failed to start 2/5 times…
[18:42:32] [Logger:admin Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[18:42:36] [API:admin Activity] : Updating the application.
[18:42:52] [Logger Info] : Stop requested: SIGUSR1 Recieved
[18:42:52] [Core Notice] : AMP shutdown requested.
[18:42:52] [Core Notice] : Stopping Application…
[18:42:52] [Minecraft Info] : Application stop requested
[18:42:52] [Minecraft Error] : Failed to write to Minecraft server STDIN stream. Server process will be killed (if it isn’t already dead)
[18:42:52] [Core Error] : IOException
[18:42:52] [Logger Error] : [0] (IOException) : Write fault on path /home/amp/.ampdata/instances/MoleWorld01/[Unknown]
[18:42:52] [Core Error] : at IO.FileStream.WriteInternal (Byte src, Int32 offset, Int32 count)
at IO.FileStream.Write (Byte array, Int32 offset, Int32 count)
[18:42:52] [Core Notice] : Stopping Web Server…
[18:42:52] [Webserver Info] : Web server shutdown.
[18:42:52] [Core Notice] : Goodbye!
[18:44:27] [Logger Info] : Starting AMP version 2.4.6.10 (Decadeus), built 06/12/2023 17:17
[18:44:27] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:44:27] [Logger Info] : Running in a QEMU KVM environment.
[18:44:27] [Logger Info] : Purging old audit logs (this may take a moment)…
[18:44:27] [Logger Info] : OS: Linux / x86_64
[18:44:27] [Logger Info] : CPU: AMD EPYC 7543P 32-Core Processor (1C/1T)
[18:44:27] [Logger Info] : RAM: 3934MB
[18:44:27] [Logger Info] : AMP Instance ID: ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
[18:44:28] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[18:44:28] [Logger Info] : Metrics publishing is enabled at udp://193.203.164.239:12820.
[18:44:28] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[18:44:28] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:44:28] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[18:44:28] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:44:28] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[18:44:28] [Logger Info] : Licence Present: AMP Enterprise Edition
[18:44:29] [Logger Notice] : Using keypair with fingerprint +ZqFQNvQgRjYTEmb6jgkNMWeaRIW8GYJCWRdTSi7Xe8=
[18:44:29] [Logger Info] : SFTP Server started on 193.203.164.239:2225
[18:44:29] [Webserver Info] : Websockets are enabled.
[18:44:29] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[18:44:29] [Logger Info] : Webserver started on ://193.203.164.239:8082
[18:44:29] [Core Info] : Checking for AMP updates…
[18:44:29] [Logger Info] : Startup mode is UpdateAndStart.
[18:44:30] [Core Info] : AMP is up to date.
[18:44:31] [Logger Warning] : Unable to get Bedrock version data from .minecraft.net/en-us/download/server/bedrock: Data not found.
[18:44:32] [Logger Info] : Modpack cache is up-to-date.
[18:44:36] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[18:44:36] [Core Activity] : Authentication success
[18:44:38] [Logger Error] : Unable to start Minecraft Server
[18:44:38] [Core Error] : PlatformException
[18:44:38] [Logger Error] : [0] (PlatformException) : ApplicationName=‘./Minecraft/bedrock_server’, CommandLine=‘’, CurrentDirectory=‘./Minecraft/’, Native error= Cannot find the specified file
[18:44:38] [Core Error] : at Diagnostics.Process.StartWithCreateProcess (Diagnostics.ProcessStartInfo startInfo)
[18:51:25] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[18:51:25] [Core Activity] : Authentication success
[18:51:50] [Logger Info] : Stop requested: SIGUSR1 Recieved
[18:51:50] [Core Notice] : AMP shutdown requested.
[18:51:50] [Core Notice] : Stopping Application…
[18:51:50] [Minecraft Info] : Application stop requested
[18:51:50] [Minecraft Error] : Failed to write to Minecraft server STDIN stream. Server process will be killed (if it isn’t already dead)
[18:51:50] [Core Error] : InvalidOperationException
[18:51:50] [Logger Error] : [0] (InvalidOperationException) : StandardIn has not been redirected.
[18:51:50] [Core Error] : at Diagnostics.Process.get_StandardInput ()
[18:51:50] [Core Notice] : Stopping Web Server…
[18:51:50] [Webserver Info] : Web server shutdown.
[18:51:50] [Core Notice] : Goodbye!
[18:52:44] [Logger Info] : Starting AMP version 2.4.6.10 (Decadeus), built 06/12/2023 17:17
[18:52:44] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:52:44] [Logger Info] : Running in a QEMU KVM environment.
[18:52:44] [Logger Info] : Purging old audit logs (this may take a moment)…
[18:52:44] [Logger Info] : OS: Linux / x86_64
[18:52:44] [Logger Info] : CPU: AMD EPYC 7543P 32-Core Processor (1C/1T)
[18:52:44] [Logger Info] : RAM: 3934MB
[18:52:44] [Logger Info] : AMP Instance ID: ecd9a384-30bd-43fd-b2a8-40ec2c446aa3
[18:52:44] [Logger Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[18:52:44] [Logger Info] : Metrics publishing is enabled at udp://193.203.164.239:12820.
[18:52:44] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[18:52:44] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:52:44] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[18:52:44] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:52:44] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[18:52:45] [Logger Info] : Licence Present: AMP Enterprise Edition
[18:52:46] [Logger Notice] : Using keypair with fingerprint +ZqFQNvQgRjYTEmb6jgkNMWeaRIW8GYJCWRdTSi7Xe8=
[18:52:46] [Logger Info] : SFTP Server started on 193.203.164.239:2225
[18:52:46] [Webserver Info] : Websockets are enabled.
[18:52:46] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[18:52:46] [Logger Info] : Webserver started on 193.203.164.239:8082
[18:52:46] [Core Info] : Checking for AMP updates…
[18:52:46] [Logger Info] : Startup mode is UpdateAndStart.
[18:52:47] [Core Info] : AMP is up to date.
[18:52:48] [Logger Warning] : Unable to get Bedrock version data from .minecraft.net/en-us/download/server/bedrock: Data not found.
[18:52:48] [Logger Info] : Modpack cache is up-to-date.
[18:52:55] NO LOG FILE! - setting up server logging…
[18:52:54] [INFO]: Starting Server
[18:52:54] [INFO]: Version 1.17.10.04
[18:52:54] [INFO]: Session ID d79a7c47-2035-44ba-899f-d99cd627c663
[18:52:54] [INFO]: Level Name: world
[18:52:54] [INFO]: Game mode: 0 Survival
[18:52:54] [INFO]: Difficulty: 2 NORMAL
[18:52:55] [INFO]: opening worlds/world/db
[18:52:56] [INFO]: IPv4 supported, port: 0
[18:52:56] [INFO]: IPv6 supported, port: 0
[18:52:56] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[18:52:56] Version: 1.17.10.04
[18:52:56] OS: Linux
[18:52:56] Server start: 2023-12-09 18:52:54 UTC
[18:52:56] Dmp timestamp: 2023-12-09 18:52:56 UTC
[18:52:56] Upload Date: 2023-12-09 18:52:56 UTC
[18:52:56] Session ID: d79a7c47-2035-44ba-899f-d99cd627c663
[18:52:56] Failed to open curl lib from binary, use libcurl.so instead
[18:52:56] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[18:52:56] Build id: 6472255
[18:52:56] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[18:52:56] Crash
[18:52:56] [INFO]
[18:52:56] d84bc95c-ff5f-4ad0-a98b-08076d204ed1
[18:52:56] [Logger Warning] : Server failed to start 1/5 times…
[18:52:56] [Logger Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[18:53:16] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[18:53:17] [Core Activity] : Authentication success
[18:53:23] [API:admin Activity] : Starting the application.
[18:53:23] NO LOG FILE! - setting up server logging…
[18:53:23] [INFO]: Starting Server
[18:53:23] [INFO]: Version 1.17.10.04
[18:53:23] [INFO]: Session ID b4cc008f-b298-418c-93fa-a5d574e4ca58
[18:53:23] [INFO]: Level Name: world
[18:53:23] [INFO]: Game mode: 0 Survival
[18:53:23] [INFO]: Difficulty: 2 NORMAL
[18:53:24] [INFO]: opening worlds/world/db
[18:53:24] [INFO]: IPv4 supported, port: 0
[18:53:24] [INFO]: IPv6 supported, port: 0
[18:53:24] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[18:53:24] Version: 1.17.10.04
[18:53:24] OS: Linux
[18:53:24] Server start: 2023-12-09 18:53:23 UTC
[18:53:24] Dmp timestamp: 2023-12-09 18:53:24 UTC
[18:53:24] Upload Date: 2023-12-09 18:53:24 UTC
[18:53:24] Failed to open curl lib from binary, use libcurl.so instead
[18:53:24] Session ID: b4cc008f-b298-418c-93fa-a5d574e4ca58
[18:53:24] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[18:53:24] Build id: 6472255
[18:53:24] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[18:53:24] Crash
[18:53:24] [INFO]
[18:53:24] 2c11e456-16bc-4bf1-b5ad-febe0d205fa2
[18:53:24] [Logger Warning] : Server failed to start 2/5 times…
[18:53:24] [Logger Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[18:54:11] [API:admin Activity] : Updating the application.
[18:54:29] [API:admin Activity] : Starting the application.
[18:54:29] NO LOG FILE! - setting up server logging…
[18:54:29] [INFO]: Starting Server
[18:54:29] [INFO]: Version 1.17.10.04
[18:54:29] [INFO]: Session ID 7e1237f7-0ae6-492c-b671-229da3f8e23f
[18:54:29] [INFO]: Level Name: world
[18:54:29] [INFO]: Game mode: 0 Survival
[18:54:29] [INFO]: Difficulty: 2 NORMAL
[18:54:30] [INFO]: opening worlds/world/db
[18:54:30] [INFO]: IPv4 supported, port: 0
[18:54:30] [INFO]: IPv6 supported, port: 0
[18:54:30] Failed to open curl lib from binary, use libcurl.so instead
[18:54:30] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[18:54:30] Version: 1.17.10.04
[18:54:30] OS: Linux
[18:54:30] Server start: 2023-12-09 18:54:29 UTC
[18:54:30] Dmp timestamp: 2023-12-09 18:54:30 UTC
[18:54:30] Upload Date: 2023-12-09 18:54:30 UTC
[18:54:30] Session ID: 7e1237f7-0ae6-492c-b671-229da3f8e23f
[18:54:30] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[18:54:30] Build id: 6472255
[18:54:30] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[18:54:30] Crash
[18:54:30] [INFO]
[18:54:30] e6c1bd4d-b4ea-4d4e-b17d-0693239ae036
[18:54:30] [Logger Warning] : Server failed to start 3/5 times…
[18:54:30] [Logger Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[19:02:06] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[19:02:06] [Core Activity] : Authentication success
[19:02:25] [Logger Activity] : Authentication attempt for user admin from 193.203.164.239
[19:02:25] [Core Activity] : Authentication success
[19:02:29] [API:admin Activity] : Starting the application.
[19:02:29] NO LOG FILE! - setting up server logging…
[19:02:29] [INFO]: Starting Server
[19:02:29] [INFO]: Version 1.17.10.04
[19:02:29] [INFO]: Session ID 4f50cf92-f809-47f7-a0c3-a31ef0bd9219
[19:02:29] [INFO]: Level Name: world
[19:02:29] [INFO]: Game mode: 0 Survival
[19:02:29] [INFO]: Difficulty: 2 NORMAL
[19:02:29] [INFO]: opening worlds/world/db
[19:02:30] [INFO]: IPv4 supported, port: 0
[19:02:30] [INFO]: IPv6 supported, port: 0
[19:02:30] Failed to open curl lib from binary, use libcurl.so instead
[19:02:30] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[19:02:30] Version: 1.17.10.04
[19:02:30] OS: Linux
[19:02:30] Server start: 2023-12-09 19:02:29 UTC
[19:02:30] Dmp timestamp: 2023-12-09 19:02:30 UTC
[19:02:30] Upload Date: 2023-12-09 19:02:30 UTC
[19:02:30] Session ID: 4f50cf92-f809-47f7-a0c3-a31ef0bd9219
[19:02:30] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[19:02:30] Build id: 6472255
[19:02:30] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[19:02:30] Crash
[19:02:30] [INFO]
[19:02:30] 8ba33a01-6d9a-478d-bb6b-997bf11392ba
[19:02:30] [Logger:admin Warning] : Server failed to start 4/5 times…
[19:02:30] [Logger:admin Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[19:03:38] [API:admin Activity] : Starting the application.
[19:03:38] NO LOG FILE! - setting up server logging…
[19:03:38] [INFO]: Starting Server
[19:03:38] [INFO]: Version 1.17.10.04
[19:03:38] [INFO]: Session ID d1a8b7e7-1631-4f7d-a9f5-abf4a320a83c
[19:03:38] [INFO]: Level Name: world
[19:03:38] [INFO]: Game mode: 0 Survival
[19:03:38] [INFO]: Difficulty: 2 NORMAL
[19:03:38] [INFO]: opening worlds/world/db
[19:03:39] [INFO]: IPv4 supported, port: 0
[19:03:39] [INFO]: IPv6 supported, port: 0
[19:03:39] Failed to open curl lib from binary, use libcurl.so instead
[19:03:39] [INFO]: Package: com.mojang.minecraft.dedicatedserver
[19:03:39] Version: 1.17.10.04
[19:03:39] OS: Linux
[19:03:39] Server start: 2023-12-09 19:03:38 UTC
[19:03:39] Dmp timestamp: 2023-12-09 19:03:39 UTC
[19:03:39] Upload Date: 2023-12-09 19:03:39 UTC
[19:03:39] Session ID: d1a8b7e7-1631-4f7d-a9f5-abf4a320a83c
[19:03:39] Commit hash: 6c75de4d333599a7a426864d3782d5bc9e6a8ef8
[19:03:39] Build id: 6472255
[19:03:39] CrashReporter Key: de5c3230-7962-3b96-82a3-401309c7ac0a
[19:03:39] Crash
[19:03:39] [INFO]
[19:03:39] a25e1284-90c9-4bb4-b3ec-ff90db6dd237
[19:03:39] [Logger:admin Warning] : Server failed to start 5/5 times…
[19:03:39] [Logger:admin Warning] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
did you hit update inside the bedrock instance when you restarted your instance cause your still sitting on the old version. if you did then there is a new box for Bedrock in the Server Configuration part of the panel. you will need to add version that you are using (checking current bedrock version its 1.20.50.04)
Correct? I noticed that too, didn’t know if MCServer matched MCClient versions
I see the “[19:36:16] [API:admin Activity] : Updating the application.” in the logs and now just again. But other than that single line after hitting update. I see the little download GUI widget in the bottom when I click it.
I would expect a bit more from the audio log other than a single line of updating… it’s like it doesnt take any futher steps? Or am I just naive?
it needs to and yes that button
