| Product | AMP ‘Callisto’ v2.5.0.12 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Starting |
Attempted to follow this guide and troubleshooted many different things on my own, unable to get the instance to recognize or show the capability for backups on the RAID array.
Array is fully built and able to read and write data from it. Permissions should be sorted out since while I am logged into the local amp user Ubuntu profile it lets me create and delete folders off the array.
Anytime I revert changes back to default the backups tab re-appears.
Direction below pasted but put in my info for the server
- Stop the instance
- In ADS File Manager/SFTP edit LocalFileBackupPlugin.kvp in the instance’s directory
- Change the location for Storage.StorePath to the new location /mnt/md0/{InstanceName}/. This will place the backups in its own subfolder based on the instance name.
- Edit FileManagerPlugin.kvp in the same directory
- Change the FileManager.AdditionalVirtualDirectories to {“backups”:“/mnt/md0”} and Save. (Left side is directory in the instance directory, right side is the actual folder location)
- Start the instance in ADS"
Running Ubuntu 24.04 LTS
AMP Release “Callisto”
v2.5.0.12, built 30/05/2024 00:03
- Changed 2 files as described in the instance
- Restarted the instance
- Backups tab completely disappears, shows back if changes are reverted
