Configuration with ARK: Survival Ascended - Missing settings in UI, cant manually add
I‘ve set up the instance : Ark Survival Ascended and sadly there are a number of settings missing in the UI, particularly the Egg, dinosaur mating and growth multipliers, as well as the per level multipliers.
I have attempted to add these in manually to the configuration file (GameUsersettings.ini and Game.ini) , however when the server is started all my changes are reverted.
I have tried making just a single change to try to pin down the issue, however this also shows the same issue.
Please can you advise? Thanks!
  • Stop server
  • Check UI for settings
  • Manually amend configuration file
  • Start server
  • Configuration file is overwritten with UI configuration
See the last para here: ARK: Survival Evolved Guide
