I have installed a fresh instance of Conan Exiles. When I click start for the first time, the page just sits at “Application State: Preparing to start” and then nothing happens. Logs and console are empty.
Step 1 - Install Conan Exiles instance.
Step 2 - Try to start it.
Removed instance and added it again, same problem.
Same thing. It did the update (I can see that in the log) and then just sticks at preparing to start, and there are no further entries in the log, nothing new was added to the log after the update.
After clicking start, it switches to preparing to start and nothing else happens. As you can see, nothing further is added to the log, as if nothing actually happens after clicking start.
Just looking at the requirements for Conan, using AMPs docker mode is highly recommended for it because it has a stack of extra requirements that aren’t found in a standard Ubuntu install. It relies on Wine, xvfb and a couple of other bits.
I set up a fresh instance, enabled docker, then did the uupdate and then tried to start the server. It is stuck at preparing to start again, with nothing more in the log after the update.
Just highlighting that the current template does not specify the correct docker image (for Xvfb), so it won’t work in docker atm, until that PR is merged
I’ve merged the changes in - if you tell AMP to fetch the latest configurations (Configuration → Instance Deployment → Fetch Latest) and make a new instance, it should all work now.
I can’t get the server to start. It gets past the place it was stuck before, but now I have been looking at this for the last 10 minutes, and server has not started.
So doesn’t work with docker, doesn’t work without docker. I have only tried setting up two servers since I purchased AMP a couple of days ago. Last Oasis, which took manual steps to fix bugs in AMP to get it working, and now Conan Exiles, which doesn’t work at all it seems. Wishing I had bitten the bullet and installed these servers manually as I usually do, and not purchased AMP.
