Changing backup location for docker instances isn't working
OS Name/Version: Ubuntu Server 22.04 LTS
Product Name/Version: AMP Release “Callisto” v2.5.0.4
I want to store my instance backups on my NAS. However, before I even tried backing up to that, I tried following the instructions on this page exactly to change to a different local folder: How to change backup locations. I stopped the instance, made the changes specified in that link, and restarted the instance.
When I create a backup on the instance, though, it never shows up in /media/backups/{InstanceName}. It only exists in the Local Backup Storage for that instance.
Steps to reproduce
I’ve checked to make sure that the amp user is the owner of the /media/backups folder, and all subfolders.
I’ve also tried deleting and recreating the instance. On a side note, even with the New Instance Defaults set to /media/backups/{InstanceName}, the new instance still starts out set to ./Backups/
I’ve looked at other posts with similar issues (though most seem to be non-docker instances) and tried the suggestions there, but most of the answers seem to just point back to the guide that I followed initially
The guide is wrong. You need to mount the path on the host into the docker container via custommountbinds in instances.json. @IceOfWraith needs to update the guide xD
Ah, okay. At least I’m not going crazy.
Thanks, I’ll look for that.
The guide should be updated now.
Thanks! Got it working now.
Thanks boss! I’m too lazy to do it
