OS Name/Version: Ubuntu Server 20.04 running in VM on Truenas
Product Name/Version: AMP v2.3.4.4 built 26/07/2022 20:08 (Release Build)
Manually set a fixed IP to AMP, can no longer manage instances.
Console: Failure to make API call to JallysMineyServer (http://127.0.0.1:8081/API/Core/Login) - retried 10 times : The operation was canceled.
TaskCanceledException
[0] (TaskCanceledException) : The operation was canceled.
at ADSModule.WebMethods.MakeInstanceRequest (m.Http.IHttpRequest request, String REQ_RAWJSON, String requesturi) at ADSModule.WebMethods.Servers (m.Http.IHttpRequest request, String id, String REQ_RAWJSON)
IOException
[1] (IOException) : Unable to read data from the transport connection: Operation aborted.
at Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.ThrowException (Net.Sockets.SocketError error) at Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.GetResult (Int16 token) at Net.Http.HttpConnection.FillAsync () at Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync (Boolean foldedHeadersAllowed)
SocketException
[2] (SocketException) : Operation aborted
Do you have multiple IP addresses on your system? Unless you do then you shouldn’t put AMP on a fixed IP. ADS01 should be 0.0.0.0, everything else must be 127.0.0.1.
By itself that isn’t the problem - but it does warn you for good reason that rebinding ADS01 will cause problems, lots of other steps are required afterwards to get it all behaving.
