Application Deployment - AMP configuration failed with return code 69632
Product AMPService ‘Phobos’ v2.6.0.0 (Mainline)
add an instance or manage instances
all my instances that i was running before update is gone. and system wont let me add a minecraft instance gives me error AMP configuration failed with return code 69632 cant add an instance after updating to 2.6.0.0
  • restarted amp, restarted server
  • restarted server and restarted anp
  • restarted server and restarted amp
  • tried to add instance
  • cant add an instance after updating to 2.6.0.0
I am getting the same issue with 1 of my instances. I tried the
ampinstmgr reactivateall insert-key-here-with-my-actual-key
that worked for 2 of the instances but then I am now getting for the only one that didn’t reactivate. None of the 3 instances will start up as of yet.
[Error/4] Couldn’t reconfigure the instance: AMP configuration failed with return code 69632
I also keep seeing this error:
[Error/1] Failed to read instance data: Newtonsoft.Json.JsonReaderException: Error reading JObject from JsonReader. Current JsonReader item is not an object: String. Path ‘[0].AMPVersion’, line 28, position 27.
at Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings)
at InstanceManagerPlugin.LocalInstanceManager.VersionObjectConverter.ReadJson(JsonReader reader, Type objectType, Object existingValue, JsonSerializer serializer)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable(JsonConverter converter, JsonReader reader, Type objectType, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at InstanceManagerPlugin.LocalInstanceManager.GetLocalInstances(String AlternateDefsPath)
Any ideas would be great!
Hi, any news about this? Just updated 2.6.0.2 and all Minecraft instances are gone
impossible to create a new one AMP configuration failed with return code 69632
I am also having this exact issue. Updated AMP and now all my instances are gone and it gives the 69632 error every time I try to create a new one.
Fixed yesterday uninstalling AMP, deleted all AMP folders and reinstalled (I am on windows)
Update AMP Instance Manager: How to update AMP to the latest version
Also having the exact same error
I am also experiencing this issue after an AMP update. The instances still exist but are considered unmanaged, trying to recreate an instance to SFTP the old datastore into the new directory results in this error.
Did a bit of digging, following the process here (AMP Instance Manager Not Working After Update - #2 by ThePotatoKing) allowed instances to be installed again, however the original ones are still not recovered. Backup the instances you already have as adding the new ones appears to be overwriting the original folders.
