| Operating System | Linux - Ubuntu 26.04 on x86_64 |
| Product | AMP ‘Proteus’ v2.8.0.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
Trying to get ADS to start up on boot even tho it should start.
ADS not autostart -on boot even tho the info says yes:
ampinstmgr -i ADS01
[Info/1] AMP Instance Manager v2.8.0.6 build 20260923.2 built 23/09/2026 16:25
Instance ID │ 9d8baa6b-338a-470b-b94d-606d2a24222b
Module │ ADS
Instance Name │ ADS01
Friendly Name │ ADS01
URL │ -
Running │ No
Runs in Container │ No
Runs as Shared │ No
Start on Boot │ Yes
AMP Version │ 2.8.0.6
Release Stream │ Mainline
Data Path │ /home/amp/.ampdata/instances/ADS01
and i have to start it manually every time
- Start the pc
- ssh onto it
- log into sudo
- Log into amp profile by using su -l
- run ampinstmgr -i
- it says that ADS01 would have been started on boot
- Ts did not start on boot
- start it manually by running ampinstmgr -s ADS01
- Finally can use amp normally
