OS Name/Version: Debian 12
Product Name/Version: 2.5.1.4 - 20240801.2
Amp Control panel not starting again after restart. But starting after reboot of the server
Update not recognized by amp panel Debian is telling me ist on 2.5.1.6
Backups not possible. There is absolutly no error in the console and no backup is created after clicking botton
Checking for update in console
`sudo apt upgrade ampinstmgr
- Step 1: Restarted
- Step 2: try to update via control panel
- Step 3: help
Ok I managed to update amp by doing this
sudo su - amp
ampinstmgr upgradeall
But all the other problems are still present
@CubeCoders-Bot Examine this users AMPs logs, see if anything’s up. Also look at the diagnostics information in AMPs support tab.
Alright, let’s dive into this! First up, let’s examine those logs from AMP to see what’s going wrong.
Could you upload the AMP logs for the instance that’s having these issues? You can find them by right-clicking the instance in the AMP panel and selecting “View Logs.” Paste the log contents as text here so I can take a look.
Once you get the logs up, we’ll have more clues to work with.
@CubeCoders-Bot
io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:346) ~[netty-codec-4.1.97.Final.jar:4.1.97.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:318) ~[netty-codec-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:444) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:420) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:412) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:286) ~[netty-handler-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:442) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.handler.flush.FlushConsolidationHandler.channelRead(FlushConsolidationHandler.java:152) ~[netty-handler-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:440) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.epoll.AbstractEpollStreamChannel$EpollStreamUnsafe.epollInReady(AbstractEpollStreamChannel.java:800) ~[netty-transport-classes-epoll-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.epoll.EpollEventLoop.processReady(EpollEventLoop.java:509) ~[netty-transport-classes-epoll-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.epoll.EpollEventLoop.run(EpollEventLoop.java:407) ~[netty-transport-classes-epoll-4.1.97.Final.jar:4.1.97.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997) ~[netty-common-4.1.97.Final.jar:4.1.97.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) ~[netty-common-4.1.97.Final.jar:4.1.97.Final]
at java.base/java.lang.Thread.run(Thread.java:1583) ~[?:?]
[09:24:22] [INFO]: VaKeHerUp issued server command: /shop
[09:25:58] [INFO]: VaKeHerUp issued server command: /shop
[09:26:10] [INFO]: Shop >> VaKeHerUp bought 16 x Lapis Lazuli(Ores.page1.items.18) for $115.52 with the buy screen.
[09:26:18] [INFO]: VaKeHerUp has made the advancement [Enchanter]
[09:27:45] [INFO]: [zAuctionHouseV3 v3.2.2.3]: Backup created: /AMP/Minecraft/plugins/zAuctionHouseV3/backup/items_backup_2024-08-16.json
[09:27:45] [INFO]: [zAuctionHouseV3 v3.2.2.3]: /AMP/Minecraft/plugins/zAuctionHouseV3/items.json successfully saved !
[09:28:40] [INFO]: [Geyser-Spigot]: Faboline has disconnected from the Java server because of Bedrock client disconnected
[09:28:40] [INFO]: [floodgate]: Floodgate player logged in as ~Faboline disconnected
[09:28:40] [INFO]: ~Faboline lost connection: Disconnected
[09:28:40] [INFO]: ~Faboline left the Server!
[09:28:56] [INFO]: [Geyser-Spigot]: Player connected with username Faboline
[09:28:56] [INFO]: [Geyser-Spigot]: Faboline (logged in as: Faboline) has connected to the Java server
[09:28:56] [INFO]: [Geyser-Spigot]: Faboline has disconnected from the Java server because of Versucht sich als Java Edition Player anzumelden! Ist Floodgate richtig eingerichtet?
[09:28:56] [WARN]: [Geyser-Spigot]: Cannot reply to ClientboundHelloPacket without profile and access token.
[09:28:56] [INFO]: Faboline (/192.168.2.1:0) lost connection: Disconnected
[09:29:04] [INFO]: [Geyser-Spigot]: Player connected with username Faboline
[09:29:04] [INFO]: [Geyser-Spigot]: Faboline (logged in as: Faboline) has connected to the Java server
[09:29:05] [INFO]: [floodgate]: Floodgate player logged in as ~Faboline joined (UUID: 00000000-0000-0000-0009-01fe6dab1e48)
[09:29:05] [INFO]: [GriefPrevGUI]: Loaded Player Data for ~Faboline.
[09:29:05] [INFO]: ~Faboline[/192.168.2.1:0]: logged in with entity id 382484 at ([world]-4333.122, 70.0, -663.5784)
[09:29:05] [INFO]: ~Faboline joined the Server!
[09:30:31] [Core Activity/17] : Authentication attempt for user admin from 127.0.0.1
[09:30:31] [Core Activity/58] : Authentication success
[09:32:32] [INFO]: VaKeHerUp issued server command: /shop
[09:32:38] [INFO]: Shop >> VaKeHerUp bought 64 x Sugar Cane(Farming.page1.items.25) for $6.40 with the buy screen.
[09:32:39] [INFO]: Shop >> VaKeHerUp bought 64 x Sugar Cane(Farming.page1.items.25) for $6.40 with the buy screen.
[09:32:41] [INFO]: Shop >> VaKeHerUp bought 64 x Sugar Cane(Farming.page1.items.25) for $6.40 with the buy screen.
[09:33:03] [INFO]: VaKeHerUp issued server command: /shop
[09:33:07] [INFO]: Shop >> VaKeHerUp sold 120 x Iron Ingot(Ores.page1.items.16) for $165.60 with the quick sell screen.
[09:33:09] [INFO]: Shop >> VaKeHerUp sold 5 x Emerald(Ores.page1.items.11) for $49.25 with the quick sell screen.
[09:33:12] [INFO]: Shop >> VaKeHerUp sold 121 x Coal(Ores.page1.items.4) for $159.72 with the quick sell screen.
[09:33:19] [INFO]: VaKeHerUp issued server command: /shop
[09:33:22] [INFO]: Shop >> VaKeHerUp sold 167 x Coal(Ores.page1.items.4) for $220.44 with the quick sell screen.
[09:33:37] [FileBackup:admin Activity/15] : Creating Backup: Test
[09:33:37] [FileBackup:admin Warning/15] : Backup not taken: Backup exceeds individual size limit.
[09:33:39] [INFO]: VaKeHerUp issued server command: /shop
[09:33:49] [INFO]: Shop >> VaKeHerUp bought 3 x Diamond(Ores.page1.items.9) for $157.50 with the buy screen.
[09:34:36] [ERROR]: Could not pass event StandardPaperServerListPingEventImpl to ServerListPlus v3.5.0
java.lang.IllegalArgumentException: Name cannot be longer than 16 characters
at com.google.common.base.Preconditions.checkArgument(Preconditions.java:143) ~[guava-32.1.2-jre.jar:?]
at com.destroystokyo.paper.profile.CraftPlayerProfile.createAuthLibProfile(CraftPlayerProfile.java:273) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at com.destroystokyo.paper.profile.CraftPlayerProfile.(CraftPlayerProfile.java:41) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at org.bukkit.craftbukkit.CraftServer.createProfile(CraftServer.java:3176) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at ServerListPlus-3.5.0-Universal.jar/net.minecrell.serverlistplus.bukkit.handlers.PaperEventHandler.handlePaperServerListPing(PaperEventHandler.java:113) ~[ServerListPlus-3.5.0-Universal.jar:?]
at ServerListPlus-3.5.0-Universal.jar/net.minecrell.serverlistplus.bukkit.handlers.PaperEventHandler.onServerListPing(PaperEventHandler.java:47) ~[ServerListPlus-3.5.0-Universal.jar:?]
at com.destroystokyo.paper.event.executor.asm.generated.GeneratedEventExecutor624.execute(Unknown Source) ~[?:?]
at org.bukkit.plugin.EventExecutor$2.execute(EventExecutor.java:77) ~[paper-mojangapi-1.21.1-R0.1-SNAPSHOT.jar:?]
at co.aikar.timings.TimedEventExecutor.execute(TimedEventExecutor.java:80) ~[paper-mojangapi-1.21.1-R0.1-SNAPSHOT.jar:1.21.1-15-11b4ac7]
at org.bukkit.plugin.RegisteredListener.callEvent(RegisteredListener.java:70) ~[paper-mojangapi-1.21.1-R0.1-SNAPSHOT.jar:?]
at io.papermc.paper.plugin.manager.PaperEventManager.callEvent(PaperEventManager.java:54) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at io.papermc.paper.plugin.manager.PaperPluginManagerImpl.callEvent(PaperPluginManagerImpl.java:131) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at org.bukkit.plugin.SimplePluginManager.callEvent(SimplePluginManager.java:628) ~[paper-mojangapi-1.21.1-R0.1-SNAPSHOT.jar:?]
at com.destroystokyo.paper.network.StandardPaperServerListPingEventImpl.processRequest(StandardPaperServerListPingEventImpl.java:60) ~[paper-1.21.1.jar:?]
at net.minecraft.server.network.ServerStatusPacketListenerImpl.handleStatusRequest(ServerStatusPacketListenerImpl.java:157) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at net.minecraft.network.protocol.status.ServerboundStatusRequestPacket.handle(ServerboundStatusRequestPacket.java:22) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at net.minecraft.network.protocol.status.ServerboundStatusRequestPacket.handle(ServerboundStatusRequestPacket.java:13) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at net.minecraft.network.Connection.genericsFtw(Connection.java:325) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at net.minecraft.network.Connection.channelRead0(Connection.java:306) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at net.minecraft.network.Connection.channelRead0(Connection.java:70) ~[paper-1.21.1.jar:1.21.1-15-11b4ac7]
at io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:99) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:93) ~[netty-transport-4.1.97.Final.jar:4.1.97.Final]
at Vulcan-2.9.0.jar/io.github.repooper.packetevents.injector.modern.PlayerChannelHandlerModern.channelRead(PlayerChannelHandlerModern.java:42) ~[Vulcan-2.9.0.jar:?]
at ProtocolLib.jar/com.comphenix.protocol.injector.netty.channel.InboundPacketInterceptor.channelRead(InboundPacketInterceptor.java:42) ~[ProtocolLib.jar:?]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:346) ~[netty-codec-4.1.97.Final.jar:4.1.97.Final]
at ProtocolLib.jar/com.comphenix.protocol.injector.netty.channel.InboundProtocolReader.channelRead(InboundProtocolReader.java:25) ~[ProtocolLib.jar:?]
at io.netty.handler.codec.MessageToMessageDecoder.channelRead(MessageToMessageDecoder.java:103) ~[netty-codec-4.1.97.Final.jar:4.1.97.Final]
at io.netty.handler.flow.FlowControlHandler.dequeue(FlowControlHandler.java:202) ~[netty-handler-4.1.97.Final.jar:4.1.97.Final]
at io.netty.handler.flow.FlowControlHandler.channelRead(FlowControlHandler.java:164) ~[netty-handler-4.1.97.Final.jar:4.1.97.Final]
[09:34:39] [INFO]: VaKeHerUp issued server command: /shop
[09:34:46] [INFO]: Shop >> VaKeHerUp bought 17 x Iron Ingot(Ores.page1.items.16) for $93.83 with the buy screen.
[09:35:45] [INFO]: VaKeHerUp issued server command: /shop
[09:35:49] [INFO]: Shop >> VaKeHerUp bought 17 x Coal(Ores.page1.items.4) for $89.25 with the buy screen.
[09:37:45] [INFO]: [zAuctionHouseV3 v3.2.2.3]: Backup created: /AMP/Minecraft/plugins/zAuctionHouseV3/backup/items_backup_2024-08-16.json
[09:37:45] [INFO]: [zAuctionHouseV3 v3.2.2.3]: /AMP/Minecraft/plugins/zAuctionHouseV3/items.json successfully saved !
[09:38:03] [INFO]: Enrico_Hamburgo1 issued server command: /delhome mine
[09:38:08] [INFO]: Enrico_Hamburgo1 issued server command: /sethome mine
[09:38:55] [ERROR]: Could not pass event StandardPaperServerListPingEventImpl to ServerListPlus v3.5.0
[09:39:35] [INFO]: VaKeHerUp issued server command: /rtp
[09:40:43] [INFO]: Enrico_Hamburgo1 issued server command: /delhome mine
[09:40:45] [INFO]: Enrico_Hamburgo1 issued server command: /sethome mine
[09:40:52] [INFO]: Enrico_Hamburgo1 issued server command: /homes wolkenkratzer
Looks like we’ve got some interesting headlines in the logs…
- Backup Issue:
- Server List Ping Event Error:
Could not pass event StandardPaperServerListPingEventImpl to ServerListPlus... Name cannot be longer than 16 characters.
First Up: Backup Issue
Your backup isn’t happening because it’s exceeding the individual size limit. Let’s increase the limit:
- Open the AMP web interface.
- Use the search box in the top right to search for “backup”.
- Adjust the backup size limit to a larger value.
Next: Update Recognition
Run the following command to ensure the latest version is being recognized:
sudo su - amp
ampinstmgr --nocache upgradeall
If AMP Isn’t Restarting
AMP not restarting without a server reboot might be tied to the shutdown process.
- Ensure no hanging processes are active:
sudo systemctl status ampinstmgr
If any AMP-related processes are hanging, kill them:
sudo systemctl restart ampinstmgr
Proceed with the changes and let’s see where it gets us. Keep me posted!
I had the same issue (Ubuntu 24.04) and this solution fixed it for me
Awesome, thanks @Petro Dubinetskyi for chiming in!
So, @Pythondras, try the backup size limit increase first, followed by the ACP upgrade steps. Don’t forget to restart the AMP instance after changes.
Once done, let’s see if the issues still persist. If AMP still won’t restart without a server reboot, we’ll dig deeper.
Keep me updated on your progress!
Fixed everything for me too thx!
