Ads instence web gui will not startup after update
OS Name/Version: windows 10 / x86_64
2.4.2.0
this has happened every time i try and update amp instance it drives me insane
i will update it the instance service will continue running but the web portal never works i have ruled out that’s its a router issue and tried accessing it on the local machine and still it dose not work
i get this error in the logs evetime i try and start it up
Assembly Newtonsoft.Json was loaded for Core via fallback handler, check plugin dependencies.
how do i fix or could it be something else
  • Step 1 update amp instance
tried running installer in repair mode
running repair
rebooting
validating all files
This may help: Something not working on Windows? Try the following:
it says update sucessful but the web portal is still broke
