OS Name/Version: Windows 10 pro
AMP 2.4.3.2
When attempting to make a new instance I get “The core archive failed to download or unpack” With the following log from the console.
ZipException
[0] (ZipException) : Could not read C:\AMPDatastore\Instances\AMPCache-Mainline-2440.zip as a zip file
at Ionic.Zip.ZipFile..ctor(String fileName) at InstanceManagerPlugin.LocalInstanceManager.<UnpackArchive>() at InstanceManagerPlugin.LocalInstanceManager.<DownloadAndUnpack>()
ZipException
[1] (ZipException) : Cannot read that as a ZipFile
at Ionic.Zip.ZipFile.ReadIntoInstance(ZipFile zf) at Ionic.Zip.ZipFile._InitInstance(String zipFileName, TextWriter statusMessageWriter) at Ionic.Zip.ZipFile..ctor(String fileName)
BadReadException
[2] (BadReadException) : Bad signature (0x4F44213C) at position 0x00000000
at Ionic.Zip.ZipEntry.ReadHeader(ZipEntry ze, Encoding defaultEncoding) at Ionic.Zip.ZipEntry.ReadEntry(ZipContainer zc, Boolean first) at Ionic.Zip.ZipFile.ReadIntoInstance_Orig(ZipFile zf) at Ionic.Zip.ZipFile.ReadIntoInstance(ZipFile zf)
Create Instance Failed: The core archive failed to download or unpack
- Step 1
Start AMP - Step 2
Attempt to create new instance from GUI
I’ve attempted to update AMP to the latest version through the command line using both Ampinstmgr Upgrade ADS01 and Ampinstmgr --nocache Upgrade ADS01 which both end in
C:\WINDOWS\system32>ampinstmgr --nocache upgrade ADS01
[Info] AMP Instance Manager v2.4.3 built 15/03/2023 09:46
[Info] Release spec: ReleaseNoUpload - built by CUBECODERS/buildbot on CCL-DEV
[Info] Stopping Instance: 'ADS01'
[Info] Stopping instance ADS01...
[Info] Waiting for instance to stop...
[Info] Instance ADS01 has stopped.
[Info] Upgrading instance ADS01
[Info] Skipping cache and downloading fresh copy...
[Info] Downloading AMP from https://cubecoders.com/Downloads/Release/AMP_Latest_Release.zip...
[Info] Complete
[Error] Failed to unpack AMP.
[Error] ZipException
[Error] [0] (ZipException) : Could not read C:\AMPDatastore\Instances\AMPCache-Mainline-2440.zip as a zip file
[Error] at Ionic.Zip.ZipFile..ctor(String fileName)
[Error] [1] (ZipException) : Cannot read that as a ZipFile
[Error] at Ionic.Zip.ZipFile.ReadIntoInstance(ZipFile zf)
[Error] BadReadException
[Error] [2] (BadReadException) : Bad signature (0x4F44213C) at position 0x00000000
[Error] at Ionic.Zip.ZipEntry.ReadHeader(ZipEntry ze, Encoding defaultEncoding)
[Info] Upgrade failed
I verified that C:\AMPDatastore\Instances has the following zip files
AMP is running as admin and cmd is run as admin.
Unsure what to do next.
