| OS |
Linux |
| Platform |
Zorin OS 16.1 |
| System Type |
x86_64 |
| Virtualization |
None |
| Module |
GenericModule |
| Loaded Plugins |
FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin |
| Application Name |
AMP |
| Application Version |
2.3.4.4 |
| Release Stream |
Release |
| Build Date |
26/07/2022 20:08 |
| InstanceID |
f698ac63-16e7-46f6-b728-f7112eb5e1fb |
| Last Executable |
/usr/bin/ldd |
| Last Arguments |
–version |
| Last Process ID |
1127274 |
* Step 1 install Wreckfest instance
* Step 2 Start instance
* Step 3 instance stuck on preparing to start with no output in instance console,
i do get output on main console after i go into manage instance as follows:
:17
192.168.137.198 tried to use session ID 9fafd40c-6087-42aa-b777-13dbec5658eb - but that session belongs to 127.0.0.1
Repeated about 50 times
Actions taken to resolve so far: deleted instance and created new one several times
Did you hit Update inside the instance after managing it and before starting the server?
Also post the logs for the instance.
Oh, and Wreckfest on Linux needs Xvfb and Wine to run if you are not running in docker
Issue resolved! thank you Greelan. Had to install Xvfb, and was having issues with wine.
Its up and running now
