Windrose Plus Installation and Setup
Hi @Greenland, is there a guide for Windrose+?
I used your Windrose template. It has the option to configure WindrosePlus settings. I’ve read a bit about WindrosePlus, that it can be downloaded from GitHub and installed in the Windrose directory.
I’ve spent hours trying to figure out exactly how and in which directory it belongs, but unfortunately, I haven’t found anything, let alone where it needs to go in AMP.
It would be great if you could help me and perhaps even update the server manual; I’m sure I’m not the only one with this problem.
  1. My name is not Greenland
  2. Just wait until the functionality is merged into the main repo rather than using the dev template
  3. There is an installation setting under Configuration>Updates
  4. The guide will be updated when the main repo has the functionality, and not before
