Windrose Docker instance fails with wine: socket : Function not implemented after AMP 2.7.2.2 update — possible AF_ALG / seccomp issue?
Windrose broken after AMP 2.7.2.2 + Docker update — possible AF_ALG / seccomp issue?
OS Name/Version: Debian 12 (Bookworm), x86_64
Product Name/Version: AMP 2.7.2.2 Deimos, built 29/04/2026 19:49
After updating to AMP 2.7.2.2 my Windrose Docker instance stopped working. Existing instance fails on start, and a fresh instance also fails during update.
Existing instance error:
Starting AMP version 2.7.2.2 (Deimos), built 29/04/2026 19:49
Running in a Docker environment.
Loaded GenericModule version 2.7.2.2
Loaded steamcmdplugin
Starting the application.
Merging config file ./windrose/4129620/R5/ServerDescription.json
Slow response: Core.Start took 30077ms to complete.
Fresh instance error during update:
Fatal Error: Steamcmd needs to be online to update.
Please confirm your network connection and try again.
Note: manual SteamCMD works fine from the same instance outside of AMP’s start/update path:
/home/amp/.ampdata/instances/Windrose01/windrose/steamcmd.sh +login anonymous +quit
Loading Steam API...OK
Waiting for user info...OK
Unloading Steam API...OK
  • Update AMP to 2.7.2.2 Deimos on a host running Docker 29.4.2
  • Start an existing Windrose Docker instance
  • Observe wine: socket : Function not implemented and instance fails to start
  • Tried switching between Wine 9, Wine 10, and Wine 11 ampbase images — same error on all
  • Tried creating a fresh Windrose instance — fails during update with SteamCMD network error
  • Confirmed manual SteamCMD works fine as the amp user outside of AMP
  • Tested socket behaviour inside the container:
AF_INET TCP  — OK
AF_UNIX      — OK
AF_ALG       — FAILED: [Errno 1] Operation not permitted
  • Tested same AF_ALG socket with --security-opt seccomp=unconfined — succeeds:
AF_ALG OK with unconfined
This suggests Docker’s seccomp profile is blocking AF_ALG (kernel crypto socket, family 38) inside AMP-managed containers, and Wine is hitting that block on startup.
Docker security options on the container:
SecurityOpt=null CapAdd=null Privileged=false NetworkMode=host
Docker daemon seccomp info:
[name=apparmor name=seccomp,profile=builtin name=cgroupns]
No custom seccomp profile is in use — Docker is using its compiled-in builtin profile. Docker 29.4.2 was also updated around the same time as AMP 2.7.2.2, so this may be a collision between Docker tightening its builtin seccomp profile around AF_ALG and Wine in the ampbase image now calling AF_ALG on startup.
I’m not certain whether the root cause is on the Docker side, the ampbase Wine image side, or something changed in AMP 2.7.2.2 itself — flagging here in case others are hitting the same thing.
Is there a way to pass custom Docker security options (e.g. --security-opt) to AMP-managed containers on a per-instance basis as a workaround? And is this something being looked at on the ampbase image side?
Happy to provide any additional output or logs.
—————————————-EDIT & FIX————————————
Docker 29.4.2 SteamCMD / AMP CreateBoundSocket Fix
Disclaimer: I am not responsible if this breaks your server, Docker setup, AMP install, containers, game saves, network config, or anything else. This is just what fixed the issue on my Debian 12 AMP host. Read the commands first, make backups, and use at your own risk.
Problem
After updating Docker to 29.4.2, SteamCMD inside CubeCoders AMP Docker containers started failing with errors like:
CreateBoundSocket: failed to create socket, error [no name available] (38)
In AMP, this caused SteamCMD updates/installs to fail. Example affected flow:
Loading Steam API...CreateBoundSocket: failed to create socket, error [no name available] (38)
OK
force_install_dir "4129620"
Connecting anonymously to Steam Public...Retrying...
Retrying...
This happened with AMP installed system-wide, but game instances running inside Docker containers such as:
AMP_Windrose01        cubecoders/ampbase:wine-9-stable
Host / Environment
This was tested on:
Debian 12
Docker Engine 29.4.2
CubeCoders AMP
AMP game instance using cubecoders/ampbase:wine-9-stable
Kernel: 6.1.0-44-amd64
Before the fix, Docker showed the default built-in seccomp profile:
docker info | grep -A5 "Security Options"
Output:
Security Options:
 apparmor
 seccomp
  Profile: builtin
What fixed it
The workaround was to use a custom Docker seccomp profile based on Docker/Moby’s default profile, but with two targeted changes:
  1. Allow AF_ALG sockets.
  2. Allow the old 32-bit socketcall syscall path.
This keeps seccomp enabled. It is not the same as running containers with:
seccomp=unconfined
After the fix, Docker showed:
Security Options:
 apparmor
 seccomp
  Profile: /etc/docker/seccomp/default-plus-afalg.json
 cgroupns
Docker also prints this warning:
WARNING: daemon is not using the default seccomp profile
That warning is expected because a custom profile is being used.
Step 1 — Back up existing Docker daemon config
sudo mkdir -p /root/docker-seccomp-backup
sudo cp -a /etc/docker/daemon.json \
  /root/docker-seccomp-backup/daemon.json.backup.$(date +%F-%H%M%S) \
  2>/dev/null || true
Step 2 — Create seccomp profile directory
sudo mkdir -p /etc/docker/seccomp
Step 3 — Download Docker/Moby default seccomp profile
sudo curl -fsSL \
  https://raw.githubusercontent.com/moby/profiles/main/seccomp/default.json \
  -o /etc/docker/seccomp/default-plus-afalg.json
Verify it downloaded:
ls -lh /etc/docker/seccomp/default-plus-afalg.json
Step 4 — Add AF_ALG socket allow rule
AF_ALG is socket family number 38.
sudo python3 - <<'PY'
import json
from pathlib import Path
path = Path("/etc/docker/seccomp/default-plus-afalg.json")
with path.open("r") as f:
    profile = json.load(f)
rule = {
    "names": ["socket"],
    "action": "SCMP_ACT_ALLOW",
    "args": [
            "index": 0,
            "value": 38,
            "op": "SCMP_CMP_EQ"
syscalls = profile["syscalls"]
already = False
for entry in syscalls:
    if entry.get("names") == ["socket"] and entry.get("action") == "SCMP_ACT_ALLOW":
        for arg in entry.get("args", []):
            if arg.get("index") == 0 and arg.get("value") == 38 and arg.get("op") == "SCMP_CMP_EQ":
                already = True
if not already:
    insert_at = 0
    for i, entry in enumerate(syscalls):
        if entry.get("names") == ["socket"]:
            insert_at = i
            break
    syscalls.insert(insert_at, rule)
with path.open("w") as f:
    json.dump(profile, f, indent=2)
print("Done. AF_ALG socket allow rule is present.")
PY
Validate JSON:
python3 -m json.tool /etc/docker/seccomp/default-plus-afalg.json >/dev/null && echo "JSON OK"
Expected:
JSON OK
Step 5 — Allow old 32-bit socketcall
This was the missing part for the AMP/Wine/SteamCMD container in my case.
SteamCMD was still failing even after AF_ALG tested OK inside the container. The reason appears to be that some older/32-bit SteamCMD/Wine code paths can still hit socketcall, and Docker’s seccomp profile was returning errno 38.
Back up the profile first:
sudo cp -a /etc/docker/seccomp/default-plus-afalg.json \
  /root/docker-seccomp-backup/default-plus-afalg.before-socketcall.$(date +%F-%H%M%S).json
Patch the socketcall rule:
import json
changed = False
for entry in profile["syscalls"]:
    if entry.get("names") == ["socketcall"]:
        entry["action"] = "SCMP_ACT_ALLOW"
        entry.pop("errnoRet", None)
        entry["includes"] = {"arches": ["x86"]}
        changed = True
if not changed:
    profile["syscalls"].insert(0, {
        "names": ["socketcall"],
        "includes": {"arches": ["x86"]}
print("Done. socketcall is now allowed for 32-bit x86 processes.")
PY
Validate JSON again:
Step 6 — Configure Docker to use the custom profile
This edits /etc/docker/daemon.json without wiping other existing settings.
import json
path = Path("/etc/docker/daemon.json")
if path.exists() and path.stat().st_size > 0:
        data = json.load(f)
else:
    data = {}
data["seccomp-profile"] = "/etc/docker/seccomp/default-plus-afalg.json"
    json.dump(data, f, indent=2)
print(json.dumps(data, indent=2))
PY
Validate Docker daemon config JSON:
python3 -m json.tool /etc/docker/daemon.json
Expected to contain:
  "seccomp-profile": "/etc/docker/seccomp/default-plus-afalg.json"
If your daemon config already had other settings, those should still be present too.
Step 7 — Restart Docker
Stop AMP/game instances first if possible.
sudo systemctl restart docker
Check Docker came back:
sudo systemctl status docker --no-pager
Confirm the custom seccomp profile is loaded:
Expected:
Security Options:
 apparmor
 seccomp
 cgroupns
Again, this warning is expected:
Step 8 — Recreate the affected AMP game container
This part mattered.
Existing AMP containers may not pick up the changed Docker seccomp profile until the container wrapper is recreated.
List containers:
docker ps -a --format 'table {{.ID}}\t{{.Names}}\t{{.Image}}\t{{.Status}}'
Example:
CONTAINER ID   NAMES            IMAGE                              STATUS
aff398977831   AMP_Windrose01   cubecoders/ampbase:wine-9-stable   Up 12 seconds
Stop the affected instance in AMP first.
Then remove only the Docker container wrapper:
docker rm AMP_Windrose01
Replace AMP_Windrose01 with your actual AMP container name.
Do not delete the AMP instance itself.
Start the instance again from AMP. AMP should recreate the container using the new Docker daemon seccomp profile.
Step 9 — Verify seccomp and AF_ALG inside the AMP container
Check seccomp is still enabled:
docker exec AMP_Windrose01 grep Seccomp /proc/self/status
Expected:
Seccomp:        2
Seccomp_filters:        1
Check AF_ALG socket creation:
docker exec -i AMP_Windrose01 python3 - <<'PY'
import socket
try:
    s = socket.socket(38, socket.SOCK_SEQPACKET, 0)
    print("AF_ALG socket OK")
    s.close()
except Exception as e:
    print("AF_ALG socket FAILED:", repr(e))
PY
Expected:
AF_ALG socket OK
Check Docker is using the custom profile:
Expected:
Security Options:
 apparmor
 seccomp
 cgroupns
Result after fix
After applying the profile and recreating the AMP container, SteamCMD worked again.
Successful AMP update log:
"@sSteamCmdForcePlatformType" = "windows"
app_update 4129620 validate
 Update state (0x5) verifying install, progress: 48.09 (1462470440 / 3041100240)
 Update state (0x5) verifying install, progress: 96.87 (2945959199 / 3041100240)
 Update state (0x0) unknown, progress: 0.00 (0 / 0)
Success! App '4129620' fully installed.
quit
It also successfully installed Steam app 1007:
app_update 1007 validate
Success! App '1007' fully installed.
Rollback / Undo
If Docker releases a fixed version and you want to go back to Docker’s built-in seccomp profile, remove the custom profile entry from /etc/docker/daemon.json.
import json
if not path.exists():
    raise SystemExit("No /etc/docker/daemon.json exists.")
    data = json.load(f)
data.pop("seccomp-profile", None)
PY
Validate JSON:
Restart Docker:
Confirm Docker is back to the built-in profile:
Expected:
Security Options:
 apparmor
 seccomp
  Profile: builtin
You may also need to recreate any AMP containers again after reverting so they pick up the built-in profile.
Notes
  • This is safer than seccomp=unconfined because seccomp remains enabled.
  • The custom profile is based on Docker/Moby’s default profile.
  • The two important changes were:
    • Allow AF_ALG socket family 38.
    • Allow socketcall for 32-bit x86 processes.
  • This fixed SteamCMD inside cubecoders/ampbase:wine-9-stable for me.
  • Existing containers may need to be recreated after changing Docker’s daemon-level seccomp profile.
I had this exact same issue and this fixed my server. Heavily apprecaite you figuring this out so I didn’t have to.
I’m happy to hear it helped.
