Will not start!
OS Name/Version:
Windows Server 2022 Datacenter
Version 21H2
Installed on ‎5/‎18/‎2023
OS build 20348.2582
AMP Instance Manager v2.5.1 built 03/07/2024 19:18
It said there was an update, I clicked on update. It did whatever it normally does to update and then I started the Service because it NEVER restarts the service.
Then it would not start.
Followed the " Something not working on Windows? Try the following:"
Even though there are no instructions on how to “run it in Repair mode”.
Restarted multiple times.
Tried doing the updateall.
Tried doing the upgradeall.
Looked at the “logs”
[13:24:22] [Webserver Info/15]    : RouterTimer@10Hz with 2 jobs started
[13:24:22] [GSMyAdmin Info/6]     : Webserver started on http://0.0.0.0:8080
[13:24:22] [GSMyAdmin Info/6]     : Checking for AMP updates...
[13:24:22] [System Info/6]        : Startup mode is UpdateAndStart.
[13:24:22] [GSMyAdmin Info/13]    : A new update is available!
[13:24:28] [InstanceManager Info/3] : Waiting for AMP instance to start...
[13:24:28] [InstanceManager Notice/3] : AMP instance Minecraft02 is now running.
[13:24:35] [InstanceManager Info/9] : Waiting for AMP instance to start...
[13:24:35] [InstanceManager Notice/9] : AMP instance PalworldModded01 is now running.
[13:24:42] [GSMyAdmin Warning/12] : Slow method invocation: Login took 2948ms to complete.
[13:24:42] [GSMyAdmin Warning/12] : Slow response: Core.Login took 2988ms to complete.
[13:25:07] [InstanceManager Activity/8] : Instance PalworldModded01 has stopped
[13:25:07] [ADS Info/8]           : ADS logged stopped instance PalworldModded01 - exit code 17 (MODULE_INIT_FAILED)
[13:25:18] [GSMyAdmin:admin Warning/21] : Slow method invocation: GetSettingsSpec took 2376ms to complete.
[13:25:18] [GSMyAdmin:admin Warning/21] : Slow response: Core.GetSettingsSpec took 2378ms to complete.
[13:25:37] [ADS:admin Activity/17] : Deleting instance 42700706-3556-455e-b2b4-2b95a6cd1118
[13:25:39] [GSMyAdmin:admin Warning/17] : Slow method invocation: DeleteInstance took 2395ms to complete.
[13:25:39] [GSMyAdmin:admin Warning/17] : Slow response: ADSModule.DeleteInstance took 2398ms to complete.
[13:25:52] [GSMyAdmin:admin Warning/19] : Slow method invocation: GetSupportedAppSummaries took 32348ms to complete.
[13:25:52] [GSMyAdmin:admin Warning/19] : Slow response: ADSModule.GetSupportedAppSummaries took 32350ms to complete.
[13:25:54] [GSMyAdmin:admin Info/17] : Stop requested: AMP update requested via API
[13:25:54] [GSMyAdmin Notice/6]   : AMP shutdown requested.
[13:25:54] [GSMyAdmin Notice/6]   : Stopping Application...
[13:25:59] [GSMyAdmin Notice/6]   : Stopping Web Server...
[13:25:59] [Webserver Info/15]    : RouterTimer@10Hz stopped
[13:25:59] [GSMyAdmin Info/6]     : Web server shutdown.
[13:25:59] [GSMyAdmin Notice/6]   : Goodbye!
I miss you Casper. <3
Not sure what else to do, now it isn’t working…
