OS Name/Version:
Ubuntu 20.04.4
AMP Release “Halimede”
v2.4, built 31/08/2022 04:00
I’ve Set up the WHMCS integration.
With every Order, the Instance gets setup correctly.
But there are two problems:
- I can’t access the amp instance confiuration from WHMCS, because using the link generated, I just get thrown to a log-in screen.
- Sadly for now there is now way for me to have a Public IP directly connected to AMP, but I have a Public IP with 1:1 NAT on it. Sadly in the info panel on WHMCS it shows its local ip, not the public ip. Any way around that?
-New install
-Connect WHMCS Integration
-Setup Callback
→ Cant login using generated URL
-Tried different configurations of Auth URL
-No Log output that I could see (Log-level: 0)
