So I’ve recently setup AMP, and am connected to it locally I believe. I’ve gone into the User Management settings and created a second user, a password for the user and given it permissions as well. What I’m trying to figure out, is where you’re supposed to connect to the panel using that login.
Using the URL that leads to your AMP install.
By default AMP runs on port 8080
I’ve figured it out, I did try that at first, but since my friend isn’t using the same connection as me I had to port forward the ip address. ![]()
