When from strandard to andvanced now my instance not working
The specified instance is not running
when i strade it it stay in waiting and then go ofline
it stard happening after i upgrad to advanced
Did you reactivate your licenses with your new Advanced license key? It should have given you a new one if I remember correctly.
Check the Deployment Log for more information.
