Webpage does not load over reverse Proxy
OS Name/Version:
Ubuntu 22.04.4
AMP Instance Manager v2.5.1.2 built 24/07/2024 21:33
I cannot access the admin Page on my reverse Proxy. I have it on amp.domain.tld. It will load for a second some of the UI Items wich then will be gone. I checked in the dev tools if the reverse Proxy may be malfunctioning but all requests get 200 Status Codes. The Webinterface is available on Port 8080 but only with http. I did not use the Automatic install since i have nginx with certbot already running on my server. I copied the default nginx config from here . THe only thing i changed was replacing the domains to the subdomain and change the path of my certs. I checked the configs with
nginx -t
wich came out successful.
It worked in the beginning. I then changed some settings (I cant remember wich ones). But Im not certain if that has to something.
1 fresh install
2 nginx config from the kb
3 change some settings in the admin ui
I reinstalled amp. Aswell as checked the nginx config File
Is the reverse proxy on the same host as AMP? If so did you let AMPs installer configure it?
Yes Its on the same host running as a systemd Service.
No I did not because there are other sites running wich depend on nginx.
And I did not know if it would just add a config file to the
/etc/nginx/sites-enabled/ Directory. Its exactly the Template with just the changes in the Domainnames and SSL Certs.
