OS Name/Version: Debian 12
Product Name/Version: AMP Release “Phobos” v2.6.3.2, built 22/10/2025 11:11
AMP does not correctly save the Virtual Path settings in the instance.json.
Each time I configure the settings exactly as shown in your ARK Cluster tutorial, AMP rewrites them incorrectly.
It saves them like this:
"OverlayPath": null,
"ExtraContainerPackages": [],
"CustomMountBinds": {
"/home/amp/arkcluster": ":ro"
"CustomPorts": [],
"DatastoreId": -1,
However, it should be saved like this:
"CustomMountBinds": {"/home/amp/arkcluster":"/AMP/ark-se/376030/arkcluster"},
"CustomPorts": [],
"DatastoreId": -1,
- Create a new instance
- Add a container path mount (specifically the cluster directory as shown in your tutorial)
- AMP saves it incorrectly and the instance fails
Actions taken so far:
Manually editing the instance.json, but AMP periodically overwrites the settings.
