OS Name/Version:
Ubuntu Server 20.04
Vintage Story 1.20.0-pre.6
Amp 2.5.1.8
I had a working Vintage Story server but wanted to try the new pre build. Deleted the old save and player data
- Step 1: change setting to preview and select the 1.20.0-pre.6 version
- Step 2: run the server
- Step 3: add player to whitelist
- Step 4: try to connect to server get message “was not able to establish udp connection.”
Looked that the port was correctly port forwarded. Made sure there was a firewall rule for the port. Tried setting the config for auth to false didn’t work. Tried with public and local ip to connect same thing.
SOLVED: The new update added a UDP port so make sure to add it
