Vintage Story fresh install running out of memory
OS Name/Version: Ubuntu server 20.04
Vintage story docker running on version 2.5.1.8
Fresh instance install of Vintage Story, no matter the settings. Everything is up to date. Never happened on past installs. Tried multiple instances but the same error.
Unable to complete task
This task could not be completed: Starting Vintage Story… - - State: 3.
Application stopped unexpectedly with exit code 134.
  • Install Vintage Story Instance
  • Setup everything as you have done in the past. There isn’t that much.
  • Boot, or update the server. Runs out of memory in strange ways.
  • Tried to make a new instance but didn’t work
  • Allocate ram didn’t work
To my understanding there’s currently a bug with the docker image that AMP uses, so to get things rolling till there’s a fix, you might want to try running it outside of docker.
Yeah figured it out just running it outside of docker fixes it for this game atleast. Sadly for some other games I can’t run them outside so I’ll have to wait.
