Field | Value |
Product | AMP ‘Callisto’ v2.5.1.0 (Mainline) |
Virtualization | Docker |
Application | Valheim |
Module | GenericModule |
Running in Container | Yes |
Current State | Sleeping |
Use Sleep Mode With Valheim
Valheim wakes up to answer queries on the Steam query port when the query port is forwarded to the instance. Since there is almost constant traffic on the query port, this prevents Valheim from sleeping. It goes to sleep, immediately wakes up, then tries to sleep again after the configured sleep delay.
I think it would be best if traffic on the query port was ignored by the sleep logic. A direct connection to the game will wake up the server so that players can join. As a temporary work-around I have disabled port forwarding for the steam query port, but this is not ideal. It would be nice if the steam queries worked while the server was awake and active with players.
- Install Valheim instance.
- Enable sleep mode for the Valheim instance.
- Port forward the steam query port to the Valheim instance.
- Put Valheim instance to sleep.
- Valheim immediately wakes up.
