OS Name/Version: win10 home
AMP Release “Decadeus”
v2.4.3, built 14/03/2023 23:15
valheim server fails to start after enabling valheim plus under the config tab after updating.
13:59:03
Mono path[0] = 'C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Managed'
Mono config path = 'C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/MonoBleedingEdge/etc'
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/lib/usr/lib/libSystem.dylib
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/lib/usr/lib/libSystem.dylib.dll
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/libc.so.6
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/libc.so.6.dll
13:59:04
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/data-00000175706F4130.dll
13:59:05
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/data-00000175752EA040.dll
Initialize engine version: 2020.3.45f1 (660cd1701bd5)
[Subsystems] Discovering subsystems at path C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/UnitySubsystems
Forcing GfxDevice: Null
GfxDevice: creating device client; threaded=0
NullGfxDevice:
Version: NULL 1.0 [1.0]
Renderer: Null Device
Vendor: Unity Technologies
Begin MonoManager ReloadAssembly
- Completed reload, in 0.145 seconds
ERROR: Shader Sprites/Default shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
Microsoft Media Foundation video decoding to texture disabled: graphics device is Null, only Direct3D 11 and Direct3D 12 (only on desktop) are supported for hardware-accelerated video decoding.
[Message: BepInEx] BepInEx 5.4.19.0 - valheim_server (3/28/2023 12:25:30 PM)
[Info : BepInEx] Running under Unity v2020.3.45.6687953
[Info : BepInEx] CLR runtime version: 4.0.30319.42000
[Info : BepInEx] Supports SRE: True
[Info : BepInEx] System platform: Bits64, Windows
[Message: BepInEx] Preloader started
[Info : BepInEx] Loaded 1 patcher method from [BepInEx.Preloader 5.4.19.0]
[Info : BepInEx] 1 patcher plugin loaded
[Info : BepInEx] Patching [UnityEngine.CoreModule] with [BepInEx.Chainloader]
[Message: BepInEx] Preloader finished
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/data-00000175958E6030.dll
13:59:06
Loading config section AdvancedBuildingMode
Loading config section CraftFromChest
Section not enabled
Loading config section ValheimPlus
Loading key mainMenuLogo
Loading key serverBrowserAdvertisement
Loading config section PlayerProjectile
Section not enabled
Loading config section MonsterProjectile
Section not enabled
Loading config section GameClock
Section not enabled
Loading config section Brightness
Section not enabled
Loading config section Chat
Section not enabled
Fallback handler could not load library C:/AMPDatastore/Instances/SpartanWorld01/Valheim/896660/valheim_server_Data/Mono/data-0000017595E818B0.dll
13:59:07
ArgumentException: Undefined target method for patch method static bool ValheimPlus.GameClasses.Chat_AddInworldText_Patch::Prefix(Chat& __instance, UnityEngine.GameObject go, long senderID, UnityEngine.Vector3 pos, Talker+Type type, string user, string text, string senderNetworkUserId)
at HarmonyLib.PatchClassProcessor.PatchWithAttributes (System.Reflection.MethodBase& lastOriginal) [0x00047] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.PatchClassProcessor.Patch () [0x0006a] in <474744d65d8e460fa08cd5fd82b5d65f>:0
Rethrow as HarmonyException: Patching exception in method null
at HarmonyLib.PatchClassProcessor.ReportException (System.Exception exception, System.Reflection.MethodBase original) [0x0006c] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.PatchClassProcessor.Patch () [0x00095] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.Harmony.<PatchAll>b__11_0 (System.Type type) [0x00007] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.CollectionExtensions.Do[T] (System.Collections.Generic.IEnumerable`1[T] sequence, System.Action`1[T] action) [0x00014] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.Harmony.PatchAll (System.Reflection.Assembly assembly) [0x00006] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at HarmonyLib.Harmony.PatchAll () [0x0001b] in <474744d65d8e460fa08cd5fd82b5d65f>:0
at ValheimPlus.ValheimPlusPlugin.Awake () [0x00048] in <7c2de1882abc413da7273413f1d1b902>:0
UnityEngine.GameObject:Internal_AddComponentWithType(Type)
UnityEngine.GameObject:AddComponent(Type)
BepInEx.Bootstrap.Chainloader:Start()
UnityEngine.Application:.cctor()
UnityEngine.InputSystem.InputManager:InitializeData()
UnityEngine.InputSystem.InputManager:Initialize(IInputRuntime, InputSettings)
UnityEngine.InputSystem.InputSystem:InitializeInPlayer(IInputRuntime, InputSettings)
UnityEngine.InputSystem.InputSystem:.cctor()
ERROR: Shader Sprites/Mask shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader GUI/Text Shader shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
UnloadTime: 1.106900 ms
Starting to load scene:start
ERROR: Shader UI/Default shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
Couldn't create a Convex Mesh from source mesh "default" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
13:59:09
ERROR: Shader Autodesk Interactive shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
WARNING: Shader Unsupported: 'Autodesk Interactive' - All subshaders removed
WARNING: Shader Did you use #pragma only_renderers and omit this platform?
WARNING: Shader If subshaders removal was intentional, you may have forgotten turning Fallback off?
ERROR: Shader Legacy Shaders/Particles/Additive shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader Legacy Shaders/Particles/Alpha Blended shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader Legacy Shaders/Particles/Alpha Blended Premultiply shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader Unlit/Color shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader Lux Lit Particles/ Bumped shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
Shader 'Lux Lit Particles/ Tess Bumped': fallback shader 'Lux Lit Particles/ Bumped Smoke' not found
WARNING: Shader Unsupported: 'Lux Lit Particles/ Tess Bumped' - All subshaders removed
ERROR: Shader Lux Lit Particles/ Tess Bumped shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader TextMeshPro/Distance Field (Surface) shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
ERROR: Shader TextMeshPro/Mobile/Distance Field shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
WARNING: Shader Unsupported: 'TextMeshPro/Distance Field' - All subshaders removed
ERROR: Shader TextMeshPro/Distance Field shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
13:59:10
Unloading 6 Unused Serialized files (Serialized files now loaded: 0)
UnloadTime: 8.611800 ms
Only custom filters can be played. Please add a custom filter or an audioclip to the audiosource (Amb_MainMenu).
HDR Render Texture not supported, disabling HDR on reflection probe.
Setting -savedir to: Saves
Get create world Spartans
Using environment steamid 892970
Using steam APPID:892970
Server ID 90071992547409920
Authentication:k_ESteamNetworkingAvailability_Waiting
Steam game server initialized
Using default prefs
Valheim version:0.214.305
Worldgenerator version setup:2
0x000001765ABD1EB3 (Mono JIT Code) UnityEngine.Texture2D:GetPixel (int,int)
0x000001765ABD187B (Mono JIT Code) Heightmap:PaintCleared (UnityEngine.Vector3,single,TerrainModifier/PaintType,bool,bool)
0x000001765ABD07BB (Mono JIT Code) Heightmap:ApplyModifier (TerrainModifier,single[],single[])
0x000001765ABCC6AB (Mono JIT Code) Heightmap:ApplyModifiers ()
0x000001765ABC043B (Mono JIT Code) Heightmap:Generate ()
0x00000175F7ADFE43 (Mono JIT Code) Heightmap:Regenerate ()
0x0000017617AEFFDB (Mono JIT Code) Heightmap:OnEnable ()
0x00000175B7AB5000 (Mono JIT Code) (wrapper runtime-invoke) object:runtime_invoke_void__this__ (object,intptr,intptr,intptr)
0x00007FFE0C6200E0 (mono-2.0-bdwgc) mono_get_runtime_build_info
0x00007FFE0C5A2AC2 (mono-2.0-bdwgc) mono_perfcounters_init
0x00007FFE0C5ABB1F (mono-2.0-bdwgc) mono_runtime_invoke
0x00007FFDECF9C3FD (UnityPlayer) UnityMain
0x00007FFDECF994C2 (UnityPlayer) UnityMain
0x00007FFDECF811B3 (UnityPlayer) UnityMain
0x00007FFDECF804DE (UnityPlayer) UnityMain
0x00007FFDECF807E3 (UnityPlayer) UnityMain
0x00007FFDECFDDABD (UnityPlayer) UnityMain
0x00007FFDECFDDF54 (UnityPlayer) UnityMain
0x00007FFDECE3E198 (UnityPlayer) UnityMain
0x00007FFDECE3FFCD (UnityPlayer) UnityMain
0x00007FFDECE3E97B (UnityPlayer) UnityMain
0x00007FFDECE41019 (UnityPlayer) UnityMain
0x00007FFDECE40D0D (UnityPlayer) UnityMain
0x00007FFDECE2516A (UnityPlayer) UnityMain
0x00007FFDECE25210 (UnityPlayer) UnityMain
0x00007FFDECE294A8 (UnityPlayer) UnityMain
ERROR: SymGetSymFromAddr64, GetLastError: 'Attempt to access invalid address.' (Address: 00007FFDECBE69DA)
0x00007FFDECBE69DA (UnityPlayer) (function-name not available)
ERROR: SymGetSymFromAddr64, GetLastError: 'Attempt to access invalid address.' (Address: 00007FFDECBE4EAB)
0x00007FFDECBE4EAB (UnityPlayer) (function-name not available)
ERROR: SymGetSymFromAddr64, GetLastError: 'Attempt to access invalid address.' (Address: 00007FFDECBE9D6B)
0x00007FFDECBE9D6B (UnityPlayer) (function-name not available)
0x00007FFDECBEB0AB (UnityPlayer) UnityMain
ERROR: SymGetSymFromAddr64, GetLastError: 'Attempt to access invalid address.' (Address: 00007FF6C26D11F2)
0x00007FF6C26D11F2 (valheim_server) (function-name not available)
0x00007FFE3D977614 (KERNEL32) BaseThreadInitThunk
0x00007FFE3F8026A1 (ntdll) RtlUserThreadStart
========== END OF STACKTRACE ===========
A crash has been intercepted by the crash handler. For call stack and other details, see the latest crash report generated in:
* C:/Windows/SERVIC~1/NETWOR~1/AppData/Local/Temp/IronGate/Valheim/Crashes
- Step 1
- Step 2
- Step 3
Actions taken to resolve so far: i tried updating the instance and the server, nothing seems to work.
