| OS | Linux |
| Platform | Debian GNU/Linux 12 |
| System Type | x86_64 |
| CPU Model | Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz |
| CPU Layout | 1S/4C/4T |
| Installed RAM | 7906 |
| Virtualization | Docker |
| Network Mode | Host Mode |
| Module | GenericModule |
| Module Application | Valheim |
| Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin |
| Application Name | AMP |
| Application Version | 2.6.0.0 |
| Codename | Phobos |
| Tools Version | 2.6 |
| Release Stream | Mainline |
| Build Spec | Release |
| Build Date | 25/10/2024 12:22 |
| InstanceID | 9b8e9457-1ca7-4d98-baa0-88bf538410e6 |
| Last Executable | /AMP/Valheim/896660/valheim_server.x86_64 |
| Last Arguments | -name Abnormal -port 2456 -world PoweredByAMP -password ********** -public 1 -preset normal -saveinterval 1800 -savedir Saves -crossplay |
| Last Process ID | 1015 |
Problem Description: Valheim PlayFab consistently says reconnecting.
22:19:18
PlayFab reconnect server 'Abnormal'
Server 'Abnormal' begin PlayFab create and join network for server
Step 1: Enable Crossplay
Step 2: Start GameServer
Step 3: Wait for it to completely load
- I’ve tried setting up a brand new Valheim server, but the same thing happens.
- I’ve reinstalled the libs recommended: libpulse-dev, libatomic1, libc6.
- Restarted numerous times
- Renamed my Server, Changed Password.
- When Crossplay unchecked it works (need it checked for Xbox users)
Note: It worked at the beginning of the year, had the server off for a few months and now it no longer connects. Does anyone have any other ideas?
I’ve tried searching the internet for a few days before posting this help ticket. Any help would be greatly appreciated,
Thank you
