OS Name/Version:
Unraid 6.12.8
AMP Release "Callisto"v2.5.0.4, built 04/04/2024 18:29
Product Name/Version: Valheim/Amp
Is it possible to use a previously configured valheimplus.cfg that was used locally, within amps instance? I imported the file into the correct directory bepinex/config, but the cfg file keeps reverting to default whenever I start the server.
Is there a different place where the vh.cfg file should be placed? Is there another file within amps dirs that are pointing to the cfg file that I can change?
I have a feeling this might be related to the fact that AMP includes a VHplus GUI with the ability to edit the same settings you would within the .cfg file
Everything else is working. I have the world imported and it works alright. Ive tried replacing the default .cfg with the one I want but it keeps reverting upon server restart.
