Hi folks i have recently created a oracle cloud server on ubuntu 22.04 and installed amp on it. I wanted to create a valheim server so ive created a new instance updated it run it and it worked. However when i tried to change to crossplay it wouldn’t connect with the server with a prompt saying unable to connect. When I turned off crossplay i could join normally.
Does anyone know how to fix this issue if you have any ideas please fire away
YMMV means “Your mileage may vary”. On ARM - you’re using Emulation to run applications. There’s zero guarantee that applications will run the same way without that emulation.
